F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Front Turn Signal
Old Apr 27, 2026 | 09:43 AM
Oreod's Avatar
Oreod
Front Turn Signal
Is there an actual bulb or something similar to replace in a 2024 Clubman front turn signal? I am experiencing rapid flashing and a warning of “Left Front Turn Signal Malfunction”.
Thank you
Old Apr 28, 2026 | 06:22 AM
ek1978's Avatar
ek1978
Thank you
there is no bulb , there is LED Module for DRL / Turn Signal :
63118737589 ( EU Market )
63118737591 ( USA Market )
But can't you even tell if the turn signal is working or not .
Old Apr 28, 2026 | 08:38 AM
Oreod's Avatar
Oreod
Thank you
Sorry, it’s not working.
Old Apr 28, 2026 | 09:56 AM
WhatV8's Avatar
WhatV8
Sounds like either the module has failed internally...odd being a 2024MY...or something in the wiring is triggering the fault (i.e.- lost communication). Have you tried unplugging the electrical connector to the housing and reseating it? Not to doubt the error code, but have you confirmed that the side repeater and rear indicator are both actively flashing, just to confirm it isn't something else that failed. Also, what happens when you run your emergency flashers? Just some thoughts.
Old Apr 28, 2026 | 12:41 PM
Oreod's Avatar
Oreod
I changed to yellow drl’s a couple of years ago. I got them from ECS Tuning, I believe they were IND. The yellow drl’s still work fine, the left front turn signal, not so much. Side markers work fine, emergency flashers work, but without the left front; yellow DRL stays on. I have the OEM white modules I took off; I’ll swap it out with the IND yellow module to see that fixes it.
JustinGTP
R60/R61 Stock Problems/Issues
Nov 1, 2016 12:45 PM
brickren
Sep 30, 2012 09:02 AM
mtubesing
R57 :: Cabrio Talk (2009+)
Jun 30, 2009 01:03 PM
lhyman
Jun 13, 2007 12:26 PM
