F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Cylinder Head Temperature Sensor Replacement
Old Sep 25, 2023 | 07:07 PM
jshort74's Avatar
jshort74
Hello,
We have P1290 code (cylinder head temperature sensor) on our 2017 1.5L Clubman. I reset it once, but it returned. Though I've read this could be sign of trouble in the turbo system, I've purchase a cylinder head temperature sensor and I'd like to replace it. I've been doing some searching and I can't find a video or instructions on how to do it. I can't even find info on where it's located. Has anyone replaced their cylinder head temperature sensor? If someone can point me to some instructions on how to do it, it would be awesome. If someone could at least show me where the sensor is located, it would be a huge help.
Thanks!
Old Sep 27, 2023 | 04:52 AM
jshort74's Avatar
jshort74
Answering my own question here. I found a some rough information on the location of the sensor, so I went searching on the car and found the cylinder head coolant temperature sensor in the top of the engine block on the front facing side. You have to remove the intake manifold to get to it.
Old May 14, 2025 | 01:01 PM
carguy6908's Avatar
carguy6908
hey so was this the fix?
Old May 19, 2025 | 10:56 AM
jshort74's Avatar
jshort74
It did not. I took it to a mechanic with the tools needed to further troubleshoot and determined the wastegate is malfunctioning at times. The whole turbo assembly needs replaced. My girlfriend is currently driving it with the code as it was going to be $5000 - $7000 to replace it. Not sure if she'll ever get it fixed or not.
Old May 19, 2025 | 11:13 AM
You can get the wastegate on these cars on their own. https://www.realoem.com/bmw/enUS/sho...diagId=11_5607 number 16.
https://www.ecstuning.com/b-genuine-...658485116~oem/
Old May 19, 2025 | 11:20 AM
jshort74's Avatar
jshort74
That's news to me, but good news. My next concern would be the calibration of the waste gate. My AutoEnginuity tool, with the BMW/Mini expanded upgrade, doesn't offer the procedure. How would I go about calibrating it after replacing it?
Thanks!
Old May 19, 2025 | 01:59 PM
Its electronic so it would show a fault code and when fixed and cleared should be GTG.
Calibration i have not seen on the B38, but similar to b58 set up
DiggyDog
Jul 2, 2015 04:24 PM
Tennessee Cutty
Feb 21, 2012 07:14 PM
scs65
Jun 3, 2006 02:06 PM
