F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Help with Codes from BlueDriver OBD Scan
Old Nov 13, 2022 | 07:19 AM
TurgidFlux's Avatar
TurgidFlux
Question Help with Codes from BlueDriver OBD Scan
Hi all,
I’ll be picking up BIMMERCODE, however, in the meantime, I hoping those much more knowledgeable than I with codes can provide some feedback.
I ran a full system module scan on my Cooper S ALL4 Clubman and receive these codes. I can’t find any information about them. I could should use some guidance about how to research these on my own without bothering others, but until then, I hoping the experts on here can shed some light for me. Here is a copy of the report. I’m most concerned about the Gearbox codes.So sorry for the enormous graphic!
Any and al help is greatly appreciated! ‘
TIA
TF
Old Nov 14, 2022 | 03:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This site can help:
https://bmwfault.codes
If the car is driving fine, my suggestion would be the clear them all and see if any return.
Old Nov 14, 2022 | 04:42 AM
TurgidFlux's Avatar
TurgidFlux
Originally Posted by njaremka
This site can help:
Hi, thanks for your response. I had been to that site but will look again. I’m not familiar with codes but since they’re not PXXXX codes, I’m guessing they’re Hexadecimal codes so I’ll go down the path a bit more.
I’ll also clear them and see if they surface again.
Thank you!
Keith
Old Nov 14, 2022 | 04:09 PM
TurgidFlux's Avatar
TurgidFlux
Hey mjarenka,
Thank you! That site is great! I quickly figured they were hex codes, punched them in and up they popped. I need to go through each tomorrow and collectively review them to see if I can determine what they mean. The gearbox codes appear to be related to a bus communication issue, either the transmitter or receiver.
As you suggested, I’ll clear everything and drive a while and review them then work on analysis.
Thank you again for your help!
Last edited by TurgidFlux; Nov 14, 2022 at 04:10 PM. Reason: Added mjarenka to the message as I did a quick reply.
potzer
Jul 29, 2022 09:35 AM
LongJohnSpankin
Jul 17, 2017 01:25 PM
turbo224
Nov 25, 2015 10:02 AM
Nimrandir
R60/R61 Stock Problems/Issues
Oct 3, 2012 05:46 AM
