F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Rear camera malfunction warning
Old Dec 9, 2019 | 04:12 PM
bmlb929's Avatar
bmlb929
Comes up every 5 minutes. Camera works fine. Ideas? Can't find anything on net.
This comes up about every 5 minutes. Camera seems to be working fine. Any ideas? Can't find much when I search the internet.
Old Apr 5, 2022 | 02:01 AM
Weyx's Avatar
Weyx
I have the same issue on the same model. Did you get yours fixed ? What was the issue ?
Old Apr 5, 2022 | 01:37 PM
reidmefirst's Avatar
reidmefirst
Mine had this issue after I got rear-ended. The repair shop replaced the camera but the new camera had to be coded. It showed up in black and white until it was coded (had to have esys plus the full psdzdata, some internet wizard did that part for me), then had to reset the stored errors in the camera. After that, no problems.
Old Nov 3, 2023 | 05:28 AM
laurentwatts's Avatar
laurentwatts
Same Error Message
Hello,
I am new to Mini (already love it), have a 2019 Clubman JCW and had the backup camera replaced at the Acura dealer where we purchased it. We now have the same Rear View Camera Malfunction message. The dealer swears they called Mini and Mini said there is not reprogramming or coding required. Is this a fix that can be done at home or do I need to take it to Mini?
My son is a Chevy mechanic and can get the Mini software for his diagnostic scanner/tool. Would this help us reprogram or reset the camera?
Thanks in advance for any advice on removing the message.
Old Nov 3, 2023 | 06:31 AM
Weyx's Avatar
Weyx
Hi ! I got mine fixed at Mini ! The fix was some glue applied to the rear camera to keep it in place in its socket.
The issue was caused by the camera having a little play in its socket, at startup the car tries to calibrate the rear-view camera, then it moves a bit so the calibration is invalid, the car tries to calibrate again and this loop continues until it gives up and throws the error "Rear view camera malfunction"
I recommend you check the camera sits firmly in place, and if not you have found your issue !
Old Nov 3, 2023 | 07:07 AM
laurentwatts
Thank you for the information, I will check that tonight when I get home!
Old Feb 3, 2024 | 08:45 AM
SWD888's Avatar
SWD888
2019 clubman rear camera error message
I had the same issue. Dealer wanted $1400 to replace it. Ummmm no thanks.... I ended up finding this thread and low and behold discover the camera was loose and rattling around. Remounted it firmly in place and bingo all is good. Really the dealer couldn't figure that out? Ugh. Thanks for the info.
emulajavi
Dec 24, 2018 09:15 AM
RedNose1
R61 :: Paceman Talk
Jul 7, 2018 08:46 PM
noppadol
Massachusetts Motoring Club
Mar 13, 2018 09:01 AM
ICONchad
May 11, 2017 06:20 PM
Street
Nov 3, 2006 10:27 PM
