Originally Posted by Walt
(Post 4576058)
Up near the top, on the right, you should see "Edward Jeong" with down arrow immediately after it. Click on the arrow, and select Private Messages.
Or, also up near the top, on the right, you should see "Welcome, Edward Jeong". Two lines below that, you should see the link Private Messages (in blue, underlined). Thank you for your help. |
Need help guys,
Can you please help me if the UJ Taillight will fit on my 2017 F54 Clubman S? It is very basic trim, no LED taillight. If yes, which part should I get? ECS Tuning says it doesn't fit on mine. https://cimg2.ibsrv.net/gimg/www.nor...e765cfbb52.jpg |
Originally Posted by maaii
(Post 4519281)
Change Brake lights and fog lights on BDC_ECU side. The fog lights will on bumper.
https://cimg7.ibsrv.net/gimg/www.nor...0dfbeb37af.jpg Just help me understand: I need to swap the: A258*2B (black/yellow) by the A258*5B (grey/yellow) and A258*5B (black/yellow) by the A2528*2B (grey/yellow) How do I know which right black/yellow wire (see my picture below) and is just pull the wire and then push? Thanks https://cimg9.ibsrv.net/gimg/www.nor...fcee09bdd1.jpg https://cimg3.ibsrv.net/gimg/www.nor...7b6752f1e7.jpg |
can you just check the “PIN number” In the plug ?
Originally Posted by Paddington_F54
(Post 4577556)
@maaii
Hello dear.
Please help me to coding Mini F54 2016 US after installation UJ tail Lights. There were halogen lamps in the car. I put the lights in the car. STOP connected in parallel STOP lamps in the bumper (STOP lamps in the bumper work together withUpper lights UJ) . With E-sys, I removed the hot and cold checks lamp: BL L / R BFD L / R FRA_H L / R The lamps work, but an error appears on the instrument panel: STOP lamps left and right are defective. I read car ISTA+, 2 errors: - 804883 Left split door tail light output faulty - 804885 Right split door tail light output faulty In E-Sys, I looked at the Mapping values for the taillights: MAPPING_BREMSL_1 = bl MAPPING_BREMSL_2 = off MAPPING_BREMSL_m = bl_m MAPPING_BRAKEFORCED_1 = off MAPPING_BRAKEFORCED_2 = bfd MAPPING_BRAKEFORCED_m = bl_m MAPPING_BLINKER_H = fra_h MAPPING_BLINKER_2_H = bfd MAPPING_PARKL_H = sl MAPPING_PARKL_H_2 = bl MAPPING_STANDL_H1 = sl MAPPING_STANDL_H2 = bl How can I remove the tail light error? Understood ... The question is closed. |
Coding for F54
hi Mai, I have just ordered the UK Tail Lights, just wonder if u can teach me which code I should do? If I got the harness do I still need to swap the pin for the brake light? Thank you
regards Karskkn [ QUOTE=maaii;4556159]Hello sir Yes, You can use bimmercode to code it, but a lot of items you need to code it one bye one please open your PM or leave email I will contact with you. Thanks[/QUOTE] |
Originally Posted by Luk84
(Post 4556162)
my pm are opened
Thank you
(Post 4561207)
Hello Ken
You can use bimmercode to code this UJ taillights. But you need to code it one by one. Many items need to code. |
Need help .... have anyone know use bimmer code for coding mini clubman f54 union jack taillight
all wiring is done .... all light is working well , just flag light not working ...... https://cimg4.ibsrv.net/gimg/www.nor...8f58b6e77.jpeg |
Mini original instructions for fitting Union Jack rear lights https://www.minif56.com/attachments/...459-pdf.73703/ seem to be much more complicated than the simple loom on here.
Another success!
Many thanks to @maaii (via @rfuller26 ) for the harness and excellent instructions! Another successful update to the UJ lights!! I am so in love with this look.
https://cimg8.ibsrv.net/gimg/www.nor...69cc07ce5e.jpg Sharp new UJ lights! |
hi,
@maaii do you ship also to Poland ? i have 2016 F54 with LED light 563 option. I assume some additional wiring will be needed to convert to UJ Tail Lights ? |
Please help!
(Post 4518824)
Problem solve. I made two adapter cables to retrofit UJ Tail Lights. It's so easy to do.
After coding, no error message pop up. https://cimg5.ibsrv.net/gimg/www.nor...e4632e6d0f.jpg https://cimg6.ibsrv.net/gimg/www.nor...325a6636c7.jpg https://cimg7.ibsrv.net/gimg/www.nor...4476b0b786.jpg https://cimg8.ibsrv.net/gimg/www.nor...297c5b1df2.jpg |
Would like help finding the wiring adaptors too - please PM me with details
PM’d
Bonjour,
J'ai acheté le Kit de post-équipement de feux arrière Facelift 63 13 2 473 459 chez MINI en France, réalisé l'installion comme ils le préconisent, fait réalisé le codage transformations (chez Mini, 119€...) Mais j'ai un PB, tout fonctionne sauf le UJ arrière gauche. Mini m'ont dit qu'il doit y avoir un problème dans mon cablage, mais non, tout est conforme. En cherchant pourquoi cela ne fonctionne pas, je m'aperçois que sur la broche 54 du BDC A258*3B il n'y a pas de tensions, d'où le fait que le UJ ne s'allume pas ! Pouvez-vous m'aider ? https://cimg6.ibsrv.net/gimg/www.nor...d5a10e5535.jpg Merci par avance car Mini me dit que je dois payer s'ils doivent regarder alors que j'ai identifié le problème (pas de tension en sortie de broche 54...) Est-ce un problème de codage Mini ? Un problème de cablage ? |
nice
i have them too
https://cimg7.ibsrv.net/gimg/www.nor...36ed38b484.jpg |
did you do the assembly yourself or at Mini? and coding / programming at Mini?
Originally Posted by dannyvdm
(Post 4619707)
i have them too
myself with NDH in netherlands...was nice job ...we did some cables...NDH some coding
working GREAT !! (now we will do headlights led) in progress |
I think Mini must have done bad coding or forgotten coding. I don't see anything else. it is not normal that there is voltage coming out of BDC 5 for the right UJ light and not from BDC 3 for the left UJ light... I would just like to be sure so as not to have to repay unnecessarily
(Post 4619711)
ja alles goed nakijken ... ik zoek nog twee led headlights voor de F54
mag lci zijn of gewoon led |
(Post 4519291)
What about, when you open the doors, do the lights in the bumper then still go on? this is a safety feature so the car is still visible when the doors are open. Does it still work after this mod?
------> Yes, use fdl coding can solve this issue. Please check the pic as below. All function works and without error. only fog light on bumper is different with LCI. https://cimg2.ibsrv.net/gimg/www.nor...66fc6f28ce.png fog light https://cimg4.ibsrv.net/gimg/www.nor...bb645da4ef.jpg reveresing lights https://cimg5.ibsrv.net/gimg/www.nor...8ca54e532c.jpg Brake lights https://cimg8.ibsrv.net/gimg/www.nor...a0ceb8dadf.jpg Turn indicator https://imgur.com/Km9ia9s May I know how to code it? Does Bimmercode can do the same? Appreciated for your help. |
PM’d
Hi maaii - please can you send me coding instructions? I've installed the lights and have bimmercode but not quite sure how to get them working.
Thank you so much. |
Harness adapter for retrofit
(Post 4556118)
Hello sir
Yes, please open your PM I will send purchase link to you. Thanks |
