F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Optimistic speedometer
Old Dec 8, 2017 | 07:24 PM
Tcgorm's Avatar
Tcgorm
i suppose many of you have noticed that your speedometer is rather optimistic. My Clubbie has HUD which is a little more realistic than the analog dial speedometer but is still off by at least 5 percent. I got a GPS speedometer app for my iPhone to check the error and sure enough it is about 5%
so so I bought one of the slick little dash mounts from Go Badges for the iPhone and it works rather well. So when I'm on the highway i plug in he phone and dial up the GPS speedo app, put the phone in the holder and that becomes my new HUD.
I checked with my dealer to see if there is a programming fix for this and they said no. I have 17" rims and may go with a slightly larger diameter tire when it's time to change to see if that helps. No AWD on he car so that shouldn't be a issue.
Anyone else experiencing this?
Old Dec 8, 2017 | 07:31 PM
punkgeek's Avatar
punkgeek
You can change this setting with bimmercode or one of the other coding apps. I forget what it is called.
Old Dec 8, 2017 | 08:00 PM
Lefooey's Avatar
Lefooey
Unfortunately, the coding change does not function on US models. I suspect one or more silly regulations at fault.
Old Dec 8, 2017 | 08:12 PM
2017All4's Avatar
2017All4
Super Moderator
Try the coding. It will not change the analog "dial" speedo, but it might change the digital readout.
Old Dec 9, 2017 | 09:40 AM
DneprDave's Avatar
DneprDave
The reason for the discrepancy is a European Union law that requires that speedometers can't read lower than the actual speed limit. There is a significant fine involved for the automobile companies, so they err on the slow side.
I put the next size bigger tires on my MINI, it brings the displayed speed to within one mile per hour of the GPS reading.
leftfield6
11
Sep 9, 2013 10:55 AM
Slave to Felines
Feb 11, 2012 07:20 AM
ghamma
12
May 28, 2011 04:11 PM
oceaneer
Jun 24, 2008 02:05 PM
Joel
Sep 18, 2002 07:41 PM
