Electrical Need a 12v power source...
Old Mar 1, 2007 | 09:33 AM
skillet's Avatar
skillet
I've got some additional lights I'm trying to install, and I need a 12v power source. Where can I tap into? Thank you!
Old Mar 1, 2007 | 10:11 AM
DixonL2's Avatar
DixonL2
Either get an "add-a-circuit" adaptor (plugs into the fuse box in place of a fuse, gives fused power to another circuit) or tie into that 12v+ battery post to the left of the airbox under the hood (on an "s" model - the place the manual tells you to attach a jumper cable). On a Cooper, you can tie into the 12v+ battery cable.
Either way, be sure to fuse the power wire. The adaptor has a fuse built in. Also protect the power wire by making sure it doesn't come adrift under the hood, doesn't rub against anything, and is concealed within a wiring loom or protective cover to prevent abrasion over time.
You can see the attach-a-circuit in my fuse box at the bottom of this picture
Old Mar 1, 2007 | 11:39 AM
Paul_TMQ's Avatar
Paul_TMQ
I kept this link as a reference for the Littlefuse Add-A-Circuit Fuseholder:
http://www.partsexpress.com/pe/pshow...83&PID=1828117
Of course, Littlefuse produce should be available at your local auto parts store (more than likely something they will have to order).
Old Mar 1, 2007 | 01:49 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
My local Advanced Auto Parts has them in stock.
Old Mar 2, 2007 | 12:05 PM
DixonL2's Avatar
DixonL2
That's pretty much what I have...
Old Mar 7, 2007 | 01:05 PM
jwardell's Avatar
jwardell
I have instructions on my web site for a normal low-power (electronics) tap:
http://www.jwardell.com/mini/fusetap.html
Be aware the add-a-circuit is only to be used up to 15A. If you mean you are adding additional headlights or a stereo amp or something powerful, then a direct tap of the battery or front power post plus a dedicated inline fuse is the best choice.
Filmy
15
Jun 6, 2023 06:27 AM
twriter
Oct 2, 2015 03:14 PM
paul7878
Sep 14, 2015 07:44 AM
Emnotek
Sep 11, 2015 04:16 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
