Electrical Fog light switch
Old Nov 14, 2006 | 06:15 AM
Half Moon Auto's Avatar
Half Moon Auto
Fog light switch
Hey,
A customer of Mine has an Orciari body kit and wants to wire in a fog light switch. Anybody know who makes a good switch that we could mount under the steering wheel. MINI makes a factory panel with a switch option but its $200 bucks! I think he's looking to spend more like $40
Justin
Old Nov 14, 2006 | 07:08 AM
Frodo's Avatar
Frodo
I have had a Orciari body kit for a while now. What is he going to do? install factory fog lights or try to install aftermarket? Might be easier with the OEM lights and the Orciari kit.
The actual switch panel is a lot cheaper than that (at least when I bought one for the rear fog lights).
For $200 sounds like an OEM retrofit kit which should include the switch panel, wiring, and lights. I don't know for sure.
Old Nov 14, 2006 | 07:51 AM
Half Moon Auto
Hey Frodo!
Thanks for the help! He already has the fog lights installed. I'm just looking for some where to buy a good switch. Once we find that we're going to run some wires.
Justin
Old Nov 14, 2006 | 10:54 PM
Frodo's Avatar
Frodo
No problem. Keep in mind I am no pro Are they OEM or aftermarket? If they are aftermarket I would recommend using a relay. This way the switch would only have to operate the relay and let the relay deal with the amps of the lights. Depending how you set it up (relay activated by ground), you can just run one wire to the switch-to-ground. I am sure there are more people here that have more experience with that.
Good luck,
Frodo
Old Nov 14, 2006 | 11:00 PM
Motor On's Avatar
Motor On
RadioShack and electrical supply stores tend to have good finds if you it a couple, also over in the interior mods forum there is a setup of 3 OEM-esque that someone put together, its been active within the last few days I'll see if I can find it and link it.
Old Nov 15, 2006 | 05:48 AM
Half Moon Auto
thanks for the heads up... I'll take a look!
Old Nov 15, 2006 | 11:30 PM
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...ht=switch+bank
Here is what I was thinking of, you might be apble to adapt it to suit the particular need, especially if they plan on adding addition accesories in the future.
Old Nov 16, 2006 | 06:49 AM
Big Daddy's Avatar
Big Daddy
Unfortunately, this designer is not responding to posts or PMs and seems to be MIA.
Old Nov 16, 2006 | 07:23 AM
Frodo's Avatar
Frodo
http://www.mcaw.info/?page_id=3
This is another option but I think you will need the switch bank that has the fog light switch.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
