Electrical Headlight Connectors?
Old Aug 22, 2006 | 04:40 PM
btrom56's Avatar
btrom56
Hi,
The street rod I am building has mini cooper headlights but did not come with the plug-in connectors. Would anyone be able to provide me with a part number? I am trying to get this part over the internet as there are no local mini dealers in my area.
Old Aug 22, 2006 | 08:03 PM
One-D's Avatar
One-D
FOr the H7's, you can use female spade connectors
Old Aug 22, 2006 | 11:16 PM
dave's Avatar
dave
pug poo picker-upper
You can look up MINI part numbers on REAL OEM
http://realoem.com/bmw/select.do?vin...ne+1.6i&arch=0
If you have xenons, they were different between the '02-04 and '05-06 builds
'02-'04 xenons look like this
http://www.motoringphotography.com/images/david03.jpg
'05-'06 xenons look like this
http://www.motoringphotography.com/images/archive18.jpg
just plug the rough build year for the headlights you have into the realoem link above and then you can seach for the headlight assembly and the connectors.
Dave
Old Aug 23, 2006 | 06:14 PM
Rawhyde's Avatar
Rawhyde
PM me if you can't find it on RealOEM. I have another source for part numbers. Maybe I can help find them. Are you using the Xenon or halogen lights? I've seen several street rods with MINI headlights and they look good. Unfortunately, every one I've seen used the halogen lights instead of the xenons.
Rawhyde
Old Aug 24, 2006 | 09:43 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The primary reason why rodders use the halogen MINI headlights besides aesthetics) rather than the HID versions is simplicity and weight. While outwardly the lamp housings are mostly similar, internally they carry the baggage of the washer assemblies and ballasts, plus the extra mechanisms for the autolevelling with the added bulk and wiring. The vast majority of rodders go for simple, clean installations. The halogen lights can be wired in just as easily as a sealedbeam lamp, where the HID versions will need either some of the attending subsystems from the MINI to work successfully, or some modifications to work stand-alone.
There are also some who would install xenons but prefer instead the cleaner, more 'retro' look of the standard halogens. The halogen trim is uniform, without the pop-up washer that would look out of place on a 30s-50s era body.
martinb
Oct 7, 2015 05:00 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
