Electrical need wiring help
Old Aug 18, 2006 | 02:11 PM
redrunner2's Avatar
redrunner2
need wiring help
I'm hooking up some new guages, and I need to tap into a any switched light bulb wire. Can anybody help me which wire would be the best to tap into.
thank you, redrunner2
Old Aug 22, 2006 | 01:20 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
You need to click on the link in my signature... Everything is explained in it...
But basically, since I see you have the heated seats, I'll help you here too...
It's very easy... First, the negative wire need to be tap into any screws under the dash (above the pedals) that touches metal...
For the positive, carefully remove the heated seats & mirrors adjustment switches. You'll see on each heated seat's switch, a red&gray wire attached to it... That wire provides power & dimmer to the switch.
Simply run a wire from your gauge to that red&gray wire and you'll be all good!!
PM me if you need any help!!
DarkMCS
Old Sep 3, 2006 | 10:29 PM
redrunner2's Avatar
redrunner2
thank you for the info.
OutMotoring
Mar 3, 2017 06:29 AM
SJ-R50
Oct 28, 2015 08:39 AM
papawhiskey
Sep 30, 2015 02:50 PM
dragonby
Sep 25, 2015 08:10 PM
