Electrical 'give me a break light' fog conversion
Old Jul 22, 2005 | 06:00 PM
MINIMAXXNC's Avatar
MINIMAXXNC
Just installed the 'Give me a Brake Light' fog light conversion kit that I ordered from myminiparts.com
Pretty sure from the instructions that came with it, that NAM's very own mini-rolls built the kit. (way to go man )
I love it. I didn't get the Fog Light option on my MINI, and have hated looking at that black plug.
Other than my son getting ahold of the splice wire and pulling off the labled taps, (I had to figure out which direction the diode needed to go)...
the install was easy. (easier than I thought it was going to be)
here are some shots..
Black hole:
New light:
ALL READY TO GO::
Thanks for making it easy mini-rolls
Old Jul 22, 2005 | 06:30 PM
goaljnky's Avatar
goaljnky
Looks good. Mine will be going in tomorrow.
Old Jul 22, 2005 | 06:59 PM
2stroke's Avatar
2stroke
I installed the reverse light kit from Mymini last week. I got tired of looking at that black plug too! The brake light looks good!
Old Jul 22, 2005 | 10:27 PM
mini-rolls's Avatar
mini-rolls
Thanks for the feedback. I am glad you like the kit and found it easy to install. I have tried to make this as easy as possible. Peter @ MYMINIPARTS is a great guy and I happy that he is carrying all my products. My wife and I just build these at home on the side trying to help MINI owners make their MINI's a little safer.
If you want to know how to use either (brake or reverse) light once my kit is installed just let me know. I have both and change the light out once and awhile just to keep people guessing.
Old Jul 23, 2005 | 05:48 AM
MINIMAXXNC's Avatar
MINIMAXXNC
backup / brake
You guys do a great job packaging that kit. "Quality" is the word that comes to mind.
I'd be curious to see what other products you make.
I think I would like to have both brake and back up...
Wouldn't you just add another tap from the back up light power?
Actually, it would be really cool to have a dual bulb light that lit up clear for back up and red for brake.
"If you build it they will come..." :smile:
Old Jul 23, 2005 | 12:07 PM
rkw's Avatar
rkw
This would be a great mod. Does the bulb and holder fill up the housing, or is there enough space to drill a hole and insert a second bulb fixture, perhaps from the side of the housing?
Old Jul 23, 2005 | 02:50 PM
MINIMAXXNC's Avatar
MINIMAXXNC
challenge
there appears to be enough room for a 2nd light, the challenge would be to split the color of the reflector, red/clear. to distinguish between braking and backing up.
any one have any ideas?
(mini-rolls I know you have something up your sleeve...)
Old Jul 23, 2005 | 05:59 PM
rkw's Avatar
rkw
This is what I've been planning to try. Use a backup light housing, which has a white/clear lens. The backup light fixture will then use its regular white/clear bulb. For the brake light fixture, simply use a red bulb (or better, one of those newer types of bulb that looks silvered but lights up red, so the unlit bulb won't show through the white lens). So, if two bulb fixtures can fit in the housing, I think this will allow both brake and backup lights to work.
It is one of the projects I had lined up for my car. I'd be doing it now except that my wife and I decided to cancel our order (after already having waited several months!) and order an '06 PW cabrio.
Now, to take it even one step further, imagine if the rear fog can do all three functions: fog light, backup, and brake! The brute force way is to try and cram three light fixtures into the housing. However, since the fog and brake are both red, there should be some way to make them share a red light bulb, and then just two light fixtures as above would be sufficient. Making the brake and fog share the same bulb would require some extra circuitry. Care to take a look at this, mini-rolls?
Old Jul 23, 2005 | 06:59 PM
goaljnky's Avatar
goaljnky
Just got my break light in. Great job, mini-rolls. Love it!
Old Jul 23, 2005 | 07:53 PM
StLouieLo's Avatar
StLouieLo
Just ordered mine Has anyone had to install the harness for a pre 10/04/04 build? Is it difficult?
Lois
Old Jul 23, 2005 | 08:20 PM
goaljnky's Avatar
goaljnky
Lois
I did. Tight quarters, but not too bad. Took me all of 15-20 minutes at most. I did see a bunch of wires running underneath the rear bumper cover. Anyone know what those are for?
Old Jul 23, 2005 | 09:45 PM
mini-rolls's Avatar
mini-rolls
Backup Sensors are what most of the wires are for.....
Old Jul 23, 2005 | 09:49 PM
StLouieLo's Avatar
StLouieLo
So, Dave...
My husband who is an electrical engineer & pretty car savvy should have no problem installing the harness & the brake light that I just ordered from you?
Lois
Old Jul 23, 2005 | 09:59 PM
mini-rolls's Avatar
mini-rolls
So, Dave...
Lois
The kit has detailed instructions with color photos and is pretty easy. I had a friend that does not work on cars or does not know anything electrical installations, follow my directions and he did it in 20 minutes. I also had a friend that is tech for MINI install it on his MINI and he thought it was a great idea. Also, just to let you know, people in my area the have early 05's without the harness ask the service manager what they can do to get a light and make it work; He gives them my number......
Old Jul 23, 2005 | 10:02 PM
StLouieLo's Avatar
StLouieLo
Thanks, Dave:smile:
Lois
Dec 23, 2015 10:36 AM
Aug 19, 2015 12:51 PM
AZN Optics
Aug 16, 2015 11:52 PM
