Electrical loose add a fuse
Old Jun 1, 2005 | 07:31 PM
argentum's Avatar
argentum
loose add a fuse
Today I installed my Euro parcel shelf with 12V outlet. I purchased an
"add-a -circuit" as has been suggested elsewhere in these forums. Everything went well until I attempted to plug in the add a circuit with a 10 amp fuse. The add a circuit module fits too loosely in the fuse slot-it has no grip at all. Now all the fuses have little notches in each metal tab which I am guessing provides a soft locking capability. The Add a Fuse tabs are straight-no notches. Could this be the problem? I know that I have the right size and I have never heard of anyone having this problem so I am kind of baffled.
Thanks for any help/suggestions
Old Jun 1, 2005 | 08:21 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Carefully give the blades of the add-a-circuit a light twist so they look something like this (but not quite as much twist, this is just to illustrate):
instead of the normal
(sorry for the awful grafix!)
This will help make better contact in the fuse block and keep the add-a-circuit from falling out. Give only enough of a twist to tighten things up, dont overdo it, and be careful not to impart too much force on the plastic body.
Old Jun 2, 2005 | 06:53 PM
argentum's Avatar
argentum
tight fuse
Thanks Greatbear. I had tried to torque the tabs a little bit and it still was very loose, but after your post I tried again with a stonger angle and managed to get a tight fit!
Filmy
15
Jun 6, 2023 06:27 AM
Hobine
Oct 7, 2015 04:52 PM
TGlax38
Sep 16, 2015 07:26 AM
Suspension Products
Sep 10, 2015 11:46 AM
Norton70
Sep 7, 2015 05:06 PM
