Electrical Iluminated door sill retrofit - 2007 Mini Cooper S R56
Old Oct 5, 2021 | 07:13 PM
CS Automotive's Avatar
CS Automotive
Hello friends,
Please your support with this thread.
I am installing the JCW iluminated door sills to my 2007 Mini Cooper S.
All cables have been runned, but need your support with the instructions to find the correct point to get the power supply.
Thanks in advanced for all your support
Old Oct 6, 2021 | 04:35 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
A good tutorial,
here:
https://www.northamericanmotoring.co...ml#post2389650
" I then ran the red power lead end and passenger side sill connection up behind the dash and over to the fuse panel and sill wire. I then made the sill connection and attached the red power lead to the violet/grey wire located in pin 8 of the blue connector on the fuse panel using the provided self-piercing wire connectors. On the drivers side, I made the sill connection, removed the control module from the two studs holding it in place, disconnected the lower wire harness, located the brown/yellow wire located in pin 35 and connected the red/black control wire to the b/y wire using the self-piercing connector. Finally, I attached the brown ground wire to the grounding clip attached to the inner lower door sill. Before securing all wires and buttoning everything back up, I reconnected the negative battery cable and SUCCESS, my sills were glowing."
I'm assuming you have an R56, but if it happens to be an R52 convertible,
the pdf of factory instructions is still easily available,
here:
R50/R52/R53 Retrofit Illuminated Sill Install Instructions courtesy of Motoring File
Old Oct 6, 2021 | 06:04 AM
CS Automotive
Thanks for your reply and support.
You are right, i have an R56.
Rgds!
lilreddot
Aug 10, 2013 02:52 PM
Cruzer214
Mar 4, 2013 07:52 PM
kevinminict
Jul 26, 2008 11:17 AM
nealwm
Jul 20, 2007 05:34 PM
ozone
Nov 25, 2006 08:12 PM
