Electrical Crimp tool pins for mini/bmw
Old Oct 23, 2019 | 06:57 AM
user 73920's Avatar
user 73920
Hi, i need a proper crimp tool for these pins. where can I find a proper tool?
tyco.mqs.0,50mm2/18/10/2019
Old Oct 23, 2019 | 08:19 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
In the past I've done many similar pins with a pair of needle nose pliers and then solder to insure a good solid connection. Might be a tool for it but unless you are doing a lot of them I don't see the need. Just a quick google will find some, "tyco.mqs.0,50mm crimper"
Old Oct 23, 2019 | 01:56 PM
user 73920's Avatar
user 73920
I've found on aliexpress a lot of crimp jaws but i don't understand which is the correct one.
Old Oct 23, 2019 | 02:30 PM
A383Wing's Avatar
A383Wing
I have the tool, Snap-on brand...if you need the tool number, I will have to go get it
Bryan
Old Oct 23, 2019 | 03:24 PM
user 73920's Avatar
user 73920
Bryan
Oh thanks. Anayway i've these jaws but the results are meh.
Old Oct 23, 2019 | 05:18 PM
A383Wing's Avatar
A383Wing
yes...same type of tool I have....but the MINI connectors might be a bit too small....try putting something on the heel of the tool so it pushes the connector up higher into the "W" portion
Bryan
Old Oct 23, 2019 | 06:30 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
You'll note the "AMP" stamped on the terminals. These are box terminals using what's known as an "f" crimp. TYCO bought out AMP Incorporated back in the late '90's. For an inexpensive tool, AMP made a SUPER CHAMP FT which should suffice. Check with your local electronics distributor or on line.
lajya
May 12, 2017 06:05 AM
MiniCJCW
Mar 9, 2017 10:07 PM
Drowninginlust
Jul 13, 2013 10:36 PM
