Electrical Invisicord install for 06 R53 with power mirror
Old Aug 10, 2019 | 12:55 PM
Husky44's Avatar
Husky44
I'm trying to install the Invisicord power cord for my radar detector tapping the power in my mirror.
Wiring diagrams are like rocket surgery to me. I thought according to the attached diagram that I would get power from the GN/BL wire in position 3, and ground from the BR/SW wire in position 10.
That did nothing.
Any help?
Old Aug 10, 2019 | 01:06 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Invisicord cord meets invisible MINI wiring = invisible result? No help from me - tut mir leid.
Old Aug 10, 2019 | 01:16 PM
Husky44's Avatar
Husky44
The picture was there when I uploaded it... :(
I'll try again.
Old Aug 13, 2019 | 12:11 AM
Eric_Rowland's Avatar
Eric_Rowland
You're trying to get power from the mirror?
Easy way is to run an add-a-fuse from the drivers side fusebox, then snake the power cord up and tuck it behind the A pillar and header. Works like a charm.
Old Aug 13, 2019 | 07:08 AM
Husky44's Avatar
Husky44
Yes, I'm trying to get power from the mirror. The Invisicord makes it pretty easy too. You just plug two pins into the back side of the wiring connection. No snaking necessary. I just need help identifying the correct wires.
Old Aug 20, 2019 | 12:37 PM
Husky44's Avatar
Husky44
Bumping to see if anyone can help me figure out if I'm reading this correctly. Please refer to original question.
Old Aug 20, 2019 | 01:27 PM
pnwR53S's Avatar
pnwR53S
I am pretty sure that you can't get power from the mirror as the "power" there is pulse width modulated (PWM) by the BCM to dim the lights. Unless your invisible thingy is designed to be able to cope with the PWM'ed power which is a feature I have not seen. However if there is a will there is a way for good engineers.
Husky44
Aug 20, 2019 12:40 PM
chapis
Jul 28, 2013 12:15 PM
Call Me SiR
Apr 20, 2012 06:13 PM
driveblind
R55 :: Clubman Talk (2008+)
Aug 31, 2009 04:49 PM
jmdor
Electrical
Dec 1, 2007 02:44 PM
