Electrical Need wiring info for base radio
Old Oct 12, 2004 | 01:46 PM
rcase13's Avatar
rcase13
Hi, Sorry if this is repeated on another thread. I searched and could not find anything directly related.
I need a 12 volt source that is only live when the radio is on. I have the base non HK radio. I want to use this 12 volt source as my amps turn-on lead.
I don't want to loose the ability to turn on the radio when the car is off.
Does such a thing exist?
Thanks,
Rodney
Old Oct 12, 2004 | 09:57 PM
CharlesT's Avatar
CharlesT
In the factory radio harness, from a 2003 Cooper S here are the factory wire colors and there purpose.
White = Powered Antenna lead
White with Red Stripe & Yellow Dots = Steering wheel controls
Grey with Red Stripe = Illumination
Red with Brown Stripe = 12V+ Constant
Purple with Blue Stripe = 12V+ Switched power
Brown = Ground
So for your application you could use the Purple w/ blue stripe or if you have your amps wired up to the battery directly then you can use the white wire to trigger your amp turn on lead.
Old Oct 13, 2004 | 09:59 AM
rcase13's Avatar
rcase13
Thanks! I will try the white wire and let you know.
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
AZN Optics
Aug 16, 2015 11:52 PM
