Electrical HID Install question
Old Feb 28, 2017 | 06:34 AM
  #26
X757XVeritas's Avatar
X757XVeritas
Yeah they just have screws holding them in from the back. You can take that plate out and make into a bracket to hold the new projectors in, or make a new bracket. I really do recommend buying some of the mentioned halogen bulbs I suggested and see how you like them first before doing a projector swap first though
Old Feb 28, 2017 | 07:03 AM
  #27
Yupoong's Avatar
Yupoong
Sounds great, I'll be looking into doing a swap soon then.
Old Feb 28, 2017 | 07:21 AM
  #28
Yupoong's Avatar
Yupoong
What size projectors did you swap into the Helix housings? H7 2.5 inch? Would like to make a list prior to doing all of this to make sure I have the right stuff
Old Feb 28, 2017 | 07:29 AM
  #29
X757XVeritas
H7 is a halogen bulb size. I'm using depo housings and acme h1 bi-xenon projectors, yes acme is a brand lol
Old Feb 28, 2017 | 07:50 AM
  #30
X757XVeritas
These are the projectors I use for my retrofits.
Due to the low price they are often sold out though
https://www.theretrofitsource.com/co...andard-h1.html
Old Feb 28, 2017 | 07:51 AM
  #31
Yupoong's Avatar
Yupoong
Oops small mistake, H7 are the high beams haha, I have an 03 MCS, doesn't it take D2R for the low beam? Or is D2R and H1 compatible like 9007 and 9004 are (with 1 wire being moved)
Old Feb 28, 2017 | 07:53 AM
  #32
X757XVeritas
The factory Xenon lights do yes. But you won't be using any of the factory HID components. You will need to purchase aftermarket ballast and wire harness and new bulbs for the new projectors.
Basically you are unplugging the big connector from the factory housing and will not be re using any of the old stuff after that when using the Depo housings.
Old Feb 28, 2017 | 07:54 AM
  #33
X757XVeritas
Post a pic of the housings you want to use and I will give you a list of everything to get
Old Feb 28, 2017 | 07:56 AM
  #34
X757XVeritas
Where are you located as well, if you happen to live close I can help out with everything
Old Feb 28, 2017 | 07:57 AM
  #35
Yupoong's Avatar
Yupoong
I'll be using https://www.ecstuning.com/b-helix-pa...ini01hl-b~hlx/ these housings, as I'm blacking the car out. I currently have xenon headlights with washers, thanks for the help sorry for the confusion also haha, I live in PA, about an hour from Philadelphia
Old Feb 28, 2017 | 07:58 AM
  #36
X757XVeritas
No confusion. Just making sure I give you the right advice, and I'm down in Va, that's a bit far lol. But I will get a list together for you tonight of what to buy
Old Feb 28, 2017 | 08:04 AM
  #37
Yupoong's Avatar
Yupoong
Awesome! Thanks a ton! Feel free to pm me also, I will probably be pming you with more questions haha
Old Feb 28, 2017 | 08:08 AM
  #38
X757XVeritas
Unless there is anything personal let's keep posting here to add to the information if someone else stumbles upon this thread
Old Feb 28, 2017 | 08:22 AM
  #39
Yupoong's Avatar
Yupoong
Sounds fine to me, thanks for the help
Old Feb 28, 2017 | 06:24 PM
  #40
Burkee52's Avatar
Burkee52
Originally Posted by Yupoong
What housing did you have in your car before you swapped to these housings? I want to do the swap, but am unsure how it will go from the xenon stock housings with headlight washer
My car currently still has the headlight washer tubes. I just unplugged them and tucked them up into the hood of the car. And of course the headlight washer fluid is empty so none of it leaks into the engine bay. I definitely like the way these headlights look better and to be honest i never even used the headlight washer function. Seems pointless to me lol
Old Feb 28, 2017 | 06:31 PM
  #41
Burkee52's Avatar
Burkee52
Damn tons of great info Veritas!! Yea i guess i never realized that there are halogen projectors as well as HID projectors lol. Well at some point ill have to look into converting those Depo headlights. I guess i'm still unsure as well what would go into that though.
Old Feb 28, 2017 | 08:51 PM
  #42
X757XVeritas
Go back to post #30 for a link to the projectors to fit in the Depo housings, on page 1 I also posted to great high output halogen bulbs as well
Old Mar 1, 2017 | 05:24 PM
  #43
Burkee52's Avatar
Burkee52
Awesome thanks! so when installing this new set up the ballast will still be on the outside of the headlight housing correct? thats one concern of mine is not having the headlight be entirely water tight. I would prefer not to risk drilling a hole in the back to allow the wires to feed through for a HID.
Old Mar 1, 2017 | 06:17 PM
  #44
X757XVeritas
You will have to drill a hole and run wires through. I used a rubber grommet and sealed the edge of it with silicone.
Old Mar 1, 2017 | 08:13 PM
  #45
Yupoong's Avatar
Yupoong
Okay, so I'm a bit confused at this moment. What style connector is used for the low beam (factory xenon) since you said we'll be using an H1 projector, obviously we'll be needing an H1 style HID kit. But what style is the connector the Hid kit will plug into?
I understand the high beam uses an H7 plug, but what does the low beam use? H1 style? Or are we completely swapping to a different plug style?
Old Mar 2, 2017 | 03:33 AM
  #46
X757XVeritas
I'll take some pictures this weekend, still need to make the list for you
Old Mar 2, 2017 | 12:31 PM
  #47
ONEBUNCHMIN's Avatar
ONEBUNCHMIN
So I can't just use H7 bulbs in a projector with my car that came with hid's? Im guessing I'll have to program it? I really don't want to "Make" my own bracket or drill anything out.
Old Mar 2, 2017 | 12:40 PM
  #48
X757XVeritas
H7 is a halogen bulb size. If you have projectors that use h7 they are halogen projectors. Yes companies sell h7 HID bulbs but they are just re based cheap Chinese HID bulbs made to fit in the halogen projector.
An HID bulb puts out far more uv and will burn the lining out of a halogen projector eventually which will render the output abysmall.
HID bulbs are also drastically different shaped than halogen bulbs are.
A halogen projector is specifically designed to give an out put based on the shape and location of the halogen bulb in side it.
The HID sits deeper in and moves the focal point creating dead spots and unacceptable glare above the cut off point.
Before I did much research I had h7 HID system in my Depo lights. In less than a year the HID system burnt the chrome out of the projector.
I might as well have held the flashlight from my cell phone out the window while driving. It would have provided more light.
This drove me to do all this research and learn how to do all this myself.
You can buy pre made brackets, and everything made to just plug in but you will still have to take the halogen projector out and install the HID projector. All this pre made stuff can easily run you close to 400 bucks not counting the price of the depo housings as well.
Old Mar 2, 2017 | 12:44 PM
  #49
X757XVeritas
I'm at work right now guys so I can answer questions real quick but don't have time to get links. But I will be off for the next 7 days and promise I will provide links to all the appropriate supplies and parts, I will try to provide the links into clusters of what would be a whole kit at different price points, the cheaper the price the more work required obviously.
Old Mar 2, 2017 | 01:32 PM
  #50
X757XVeritas
No guarantees at the moment of this being exactly correct, was a rush jib during a free moment. Will go over it all one more time tomorrow. Consider this a rough guide
Cheap
Projector
$25
Bulbs
XenTec H1 6000K HID Xenon Bulb (1 Pair, Ultra White color)
Amazon Amazon
$12
Ballasts
uxcell Pair Car HID Xenon Mini Ballast 35W 10A 12V for H1 H3 H7 H8 H9 H10 H11
Amazon Amazon
$17
Harness adapter x2, will need to crimp male spade connectors onto the ends to plug into the h7 harness inside the housing.
https://www.theretrofitsource.com/90...test-lead.html
$1
Make your own bracket
$ potentially free
Better
Projector
$25
Bulbs
https://www.theretrofitsource.com/co...ndard-hid.html
$20
Ballasts
https://www.theretrofitsource.com/co...start-35w.html
$60
$1
$ potentially free
Best
Projectors
https://www.theretrofitsource.com/co...ni-h1-7-0.html
$130
Bulbs
https://www.theretrofitsource.com/co...to-xb-hid.html
$40
Ballasts
https://www.theretrofitsource.com/co...moto-xb35.html
$110
Brackets
http://www.lightwerkz.net/index.php/...-brackets.html
$70
$1
