Electrical Best Upgrade for reverse lights
Old Jan 26, 2016 | 09:53 PM
blue al's Avatar
blue al
Has anyone discovered the best solution for the reversing lamps
Fed up with mine
Old Feb 27, 2016 | 07:21 PM
thays_91's Avatar
thays_91
Following... So far I've tried some autoparts store led replacements which were a joke, though the color temperature was nice. and some high power bulbs but they still weren't bright enough.
Old Sep 30, 2016 | 12:54 PM
Loccusst's Avatar
Loccusst
Was wondering if there is a way to do some coding to increase the output? With these cars being canbus I imagine that the module actually controls the output to the bulb and may be able to be adjusted if it is not already at a 100% setting. This module may also limit the new bulb being brighter than what is already in there once it senses a stronger draw.
Old Sep 30, 2016 | 08:25 PM
rkw's Avatar
rkw
Originally Posted by Loccusst
Was wondering if there is a way to do some coding to increase the output? With these cars being canbus I imagine that the module actually controls the output to the bulb and may be able to be adjusted if it is not already at a 100% setting.This module may also limit the new bulb being brighter than what is already in there once it senses a stronger draw.
LED bulbs draw much LESS power than the standard bulbs they replace.
The problem is that most aftermarket LED bulbs are in fact quite dim. thays_91 didn't say which LED bulbs he bought, but the ones I see on the AutoZone website are wimpy. Look for bulbs that use Cree LED elements. These have received good reviews on Amazon: https://www.amazon.com/JDM-ASTAR-Ext.../dp/B00XB3CFUQ (haven't tried them myself).
Kishino
Oct 18, 2004 07:20 AM
ElonCooper
12
Jun 15, 2004 11:39 PM
PMC
Jan 17, 2004 10:18 AM
project_wonderboy
Oct 13, 2003 07:53 AM
JerryTheTiger
May 9, 2003 05:10 PM
