Electrical Obd II bluetooth reader
Bought a Bluetooth reader from eBay, however it doesn't work. Can anyone recommend one that they have had good luck with? I downloaded dash command and I'd like a device that is compatible with the app as well as my iPhone 6.
Thanks for your advice.
Get tje BMWhat app and their OBDII reader. It is WIFI and work with iphone. Bluetooth doesn't work with iPone from what I was told, Apple does not support Blue tooth in this instance. I have BMWhat and the reader and it works fine you can do some coding with it. Do a search on BMWhat on here there is a tread on it. You can get the reader from Amazon for $65 it is pricy and the App is $44 in the App store or iTunes. You can also use it on you iPad, which I do because it is easier to see with these old eyes than my iphone. The site is www.IVINI-apps.com There are other Wifi readers out that work also use the above thread to find which one
Tom
Tom
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
gar56
Nov 15, 2016 06:41 AM
