Electrical Disable TPMS permanently?
Old Feb 5, 2014 | 08:30 PM
jason7391's Avatar
jason7391
Do any of you guys know if you can make the tmps light stop flashing as well as the picture in the display cluster. I only track the car so i don't run tpms sensors in my slicks. I know for the airbag light all you have to do is unplug the airbag module. Was wondering if it is the same for the tmps lights. my car is a 2010 r56
Edit: I just found out that unplugging the airbag module doesn't remove the light, does anyone know how to remove that also.
Old Feb 5, 2014 | 08:53 PM
chrunck's Avatar
chrunck
A piece of carefully placed electrical tape is your best bet.
Old Feb 6, 2014 | 06:39 PM
jason7391's Avatar
jason7391
that won't remove the symbol from the display in the tach though.
Old Feb 6, 2014 | 06:48 PM
chrunck's Avatar
chrunck
Well I'm no expert, but everything I've seen says there's nothing you can do about the light. Maybe you can disable it through NCS expert, but I have no idea if that's one of the settings. If it really bugs you, the quickest and cheapest option is to just cover it up with a piece of tape.
Old Feb 6, 2014 | 07:03 PM
danjreed's Avatar
danjreed
Meh, the cluster warning only comes on for a sec. The flashing lasts only 30 seconds before going solid..
I did see that if you try to reset the system my light stays off for about 30 min..
Old Feb 6, 2014 | 07:38 PM
cerenkov's Avatar
cerenkov
You probably can do this with NCS Expert. I got this from the BMW forums, for the MINI it will be similar:
Remove tpms fuse first
- Remove 2VB from VO
- Code CAS and FRM with VO (FA_write)
- Default the proper modules for the new VO
Doc Pain
Mar 10, 2021 04:50 AM
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
renchjeep
Sep 6, 2015 01:54 PM
