Electrical Help!!!!!! No power
Old Mar 30, 2013 | 03:26 PM
thirstygreek's Avatar
thirstygreek
Help!!!!!! No power
Ok so I will prefeace this by saying I am an idiot.
I was doing suspension work when I dropped a nut down under the fuse box in my r53. I realized I needed to unscrew the fuse box to get to the nut. In the process my ratchet hit the power cable and sparks flew for a second then nada....no power to the whole car period. Battery has power, pos terminal in engine bay has power. The power cable at the fuse box has no power.
I am PRAYING their is an inline fuse that blew and saved the day and not that the whole ECU is fried.
Where should I start? Is there a fuse inline to the fuse box? Must be if there is no power to it.
All help is mucho appreciated
Old Mar 30, 2013 | 03:54 PM
Braminator's Avatar
Braminator
IMO Sounds like you blew the fusible link. It is located in the hatch next to the battery. You will see the red power cable going into a yellow box. The fuse is in that box.
Old Mar 30, 2013 | 04:00 PM
Braminator's Avatar
Braminator
I found this picture to help you. Its the fuse that is 250amps
Old Mar 30, 2013 | 06:32 PM
thirstygreek
wow great thanks!! I will check that out tomorrow morning! That would be great if it was just that fuse
Old Mar 30, 2013 | 06:41 PM
Braminator's Avatar
Braminator
You still should check all your fuses to see if you blew anything else. Good luck.
Old Nov 8, 2013 | 05:28 PM
JT911's Avatar
JT911
Did you ever find that nut? I'm facing a similar problem, but rather than a nut it's a socket. I'm assuming you disconnect the battery, remove the power connection to the fuse box and it comes out after removing the 2 bolts.
bADbOYbECK
41
Oct 16, 2015 12:39 PM
twriter
Oct 2, 2015 03:14 PM
paul7878
Sep 14, 2015 07:44 AM
Emnotek
Sep 11, 2015 04:16 PM
Ntety
Sep 2, 2015 08:39 PM
