Electrical Hatch switch stopped working after wash..
Old Mar 29, 2013 | 07:10 AM
bremworks's Avatar
bremworks
I found that after washing my R53, the hatch switch stopped working. I initially thought that it was the upper switch (push button side) so I took it all apart and found that everything was dry and looking good. Upon closer investigation, I found that there is also a micro switch on the latch side that tells the car that the hatch is closed and may need to be opened at some point. That switch is where the water and problem was. I removed the rear panel to disassemble and dry the connections/switch but if anyone else has this problem, a spray of brake clean or electrical contact cleaner into the right side of the latch should displace the water and get you going again! Hope this helps at least one person...happy Mini'ing!
On a side note, I'm down in Palm Springs for a couple of weeks and will be hanging out on the Pines to Palms in the mornings (going to the lookout and back) I'll also be over at Mt Palomar a couple times....If any Socal members are feeling saucy, shoot me a message...maybe we can coordinate a spirited drive!!
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
tippin
Aug 5, 2015 08:43 AM
