Electrical Switched power auto meter elect boost gauge
Old Mar 27, 2013 | 06:20 AM
BruceK's Avatar
BruceK
The auto meter boost gauge instructions say I need switched power that that stays on when the engine is cranked. This ensures the self calibration doesn't reset while cranking and cause inaccurate readings.
Where might I tap in the wiring harness neatly to provide the power?
I've read the install threads at http://www.billswebspace.com/R53GaugeInstallation.htm
but I'm looking for more specifics. The seat heater switch was one recommendation but I'll have to check that one with a VOM.
I just don't want to fry any control modules in the process.
Old Mar 30, 2013 | 06:48 AM
BruceK's Avatar
BruceK
No detailed descriptions?
Old Mar 30, 2013 | 07:20 PM
Da_Ghost's Avatar
Da_Ghost
You can get ignition switched power from the cigarette lighter and illumination from the lighted ring around it. I remember going for a wire in the rpm gauge on the steering for mine, but I don't remember the color.
Old Mar 30, 2013 | 10:25 PM
astroBlackMetallic_Mini's Avatar
USe the 12 v cig lighter. It's your safest bet IMO. Little bit of work routing the wires, but worth it.
Old Mar 31, 2013 | 07:19 AM
BruceK's Avatar
BruceK
I went for the seat heater switch. I found a lot of accessories stay on during cranking. I think that's because they operate at such a low voltage these days. So the gauge calibrates just fine.
Anyway everything works great except the dimmer portion of the lighting. The voltage coming off the dimmer circuit is only 3-4Vdc so the 12V bulb barely lit the gauge. I went to the same 12V wire as the gauge and now it looks pretty much the same as the OEM instruments.
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Red Raven
Aug 11, 2015 04:48 AM
