Electrical Please clarify- simplify!?!
Old Jan 4, 2013 | 08:12 PM
rayzmini's Avatar
rayzmini
Talking Please clarify- simplify!?!
I don't want to re-code... I don't want to have to "modify"... just looking for a "plug n play" That wont through any error codes a bulb to replace the "OEM" fogs that are brighter then the stock ones, sorry if I'm just being lame but I read through some of the threads on replacing these and just ended up being confused about what worked,there seems to be so many options. That being said can I just purchase a "H8" bulb and not have any issues? thanks for the clarification regarding this!
Old Jan 8, 2013 | 10:04 PM
SmithWerks's Avatar
SmithWerks
if you convert via a drop in HID kit of 35w, you will be OK
if you use another halogen H8 of 35w, you will be ok
If you run LED's you need to code out the warning
A higher wattage H8 isnt recommended as either the wiring may not handle the load?, or the housing may not handle the additional heat (ie cracking)
if you can find say a SilverStar or brigher/higher lumen rated 35w H8 halogen, you will appear to have a brighter output. Color alone can create a brighter effect.
The factory are a yellowish halogen of around 3200K(Kelvin temp), somethng in the 4300-6000K range would be a neutral white & somewhat brighter.
However, yellows (lower Kelvin spectrum colors) tend to illuminate actual fog better as they create some contrast
Old Jan 18, 2013 | 09:06 PM
rayzmini's Avatar
rayzmini
ok
thanks for the feed back I will look into it
Old Jan 19, 2013 | 11:14 AM
Theta's Avatar
Theta
I would like to correct some misinformation here.
On the R60, you will need to code the fog warning out for 35W HID ballasts. Additionally, you should be using capacitors between the H8 connector and the ballast. The PWM signal sent will burn a ballast in only a few fires if not properly coded.
On 2012+ models, you will absolutely need a capacitor or one side will generally not fire on the first try.
Old Jan 19, 2013 | 11:17 AM
bmwr606's Avatar
bmwr606
first i heard of this
what size cap?
scott
Old Jan 19, 2013 | 11:19 AM
Theta's Avatar
Theta
Generally the cheap-ie "warning removers" will work just fine. They're generally 16v 4000uf capacitors in small boxes.
The PWM signal on the 2012 is notorious for burning cheap ballasts because of the initial voltage inrush (hot->cold->hot).
The coding is crucial, as without it the PWM will continue to cycle indefinitely.
bahman
Nov 15, 2019 05:45 AM
Sep 10, 2015 11:55 AM
ToThePublic
May 31, 2014 05:30 AM
irieman
Sep 5, 2013 06:32 AM
