Electrical Power windows
Old Nov 11, 2012 | 11:42 AM
framerav's Avatar
framerav
Power windows
Hi I have have a 2003 Cooper S and my power window on the driver's side stopped. Just trying to find out where to start, the switch or the window itself.
It was working fine this morning Thanks
Old Nov 11, 2012 | 12:15 PM
MINILLA's Avatar
MINILLA
Give the door a good "thwack" with your hand a little above and rear of the door speaker...it works in most cases until it quits again then you give it another thwack! I know its not a permanent fix but it'll keep you going until you need to replace the motor etc...
Old Nov 11, 2012 | 12:26 PM
cristo's Avatar
cristo
Alliance Member
Mine's been in the "thwack" mode a couple/few times a month for a couple years now.
More often in the summer after it sits in the sun for a day or two.
I did shift the magnet in a Polk speaker in the door a year ago, probably from repeated thwacking.
I had to get a replacement mid/woofer driver.
Old Nov 20, 2012 | 09:12 PM
ammodave's Avatar
ammodave
FWIW I had a 1st generation Miata as my previous toy car and every time the windows acted up it turned out to be the switch. I replaced the switch the first time it happened; after that I just started disassembling the switch and cleaning the contacts to get them working again. Apparently, arcing inside the switches caused the contacts to get pitted and stop working.
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
hardy616
Sep 2, 2015 08:32 AM
