Electrical GOMINIGO Pulsar?
Old Apr 6, 2012 | 12:34 PM
Koopah's Avatar
Koopah
GOMINIGO Pulsar?
Has anyone installed the GMG third brake light pulsar device?
Just wondering if it works without causing any bulb-check warnings. It would be perfect if I didn't have to search through the FRM module settings and disable the bulb-check for that light.
TIA,
Theo
Old Apr 6, 2012 | 12:37 PM
Drakosd's Avatar
Drakosd
I ve been interested in this as well. Would love to hear any feedback.
Old Apr 6, 2012 | 12:41 PM
drsimmons's Avatar
drsimmons
No install problems. Works great. Make sure you measure and determine exactly where you are going to mount it before cutting any wires.
Easy install.
Old Apr 6, 2012 | 12:58 PM
Koopah's Avatar
Koopah
Easy install.
Did you install it on a Countryman?
Old Apr 6, 2012 | 01:35 PM
drsimmons's Avatar
drsimmons
Nope, hardtop.
Shouldn't be a problem. Doesn't the inside plastic cover on a CM snap in place?
Old Apr 6, 2012 | 02:51 PM
less2's Avatar
less2
Very easy install no problem at all. One of the first mods I did on my Countryman took less than a half hour. And it took that long because I couldn't fine my exacto knife to cut some of the cloth tape away. But it works like a charm just have to remember to put the jumper back in during rally's. The instructions are dead on.
Old Apr 6, 2012 | 04:37 PM
Koopah's Avatar
Koopah
Thanks drsimmons and less2. My question was more about whether the FRM module sensed "burned-out" lamps during the blinking. I had to code out all the bulb checks when I replaced lamps with LEDs. From the actual install perspective, it looks like a snap to do.
Thanks all!
Theo
Old Apr 6, 2012 | 05:49 PM
drsimmons's Avatar
drsimmons
Thanks all!
Theo
Sorry, forgot to actually answer your question but NO.
mini-rolls
Apr 30, 2007 08:23 PM
