Electrical lost list
Old Dec 9, 2011 | 01:46 PM
fredred's Avatar
fredred
lost list
i had a list of test codes and error codes, and what they mean. a link to said list or a downloadable copy would be great. if anyone can help it would be greatly appreacated. 2003 cooper chili red thanks
Old Dec 9, 2011 | 03:11 PM
fhdogs's Avatar
fhdogs
Unfortunately I only have the codes for Indie Blue. (Sorry I had to go there.)
If you are looking for P codes try here: http://www.obd-codes.com/trouble_codes/bmw/index.php
Old Dec 9, 2011 | 09:29 PM
fredred's Avatar
fredred
thanks for info
i was refering to the codes that are accessable thru odo, test codes and what they mean. at one point i had said list and procedure for access to test mode so, i know it exists. but i lost mine thanks i'll keep looking if anyone else knows ?
Old Dec 9, 2011 | 09:48 PM
fhdogs's Avatar
fhdogs
Ahhhh.... Is this what you mean?
The information displays in place of your mileometer, so you DO NOT have to have the MINI OBC/Trip Computer option to see this.
A complete list of functions is below, this example is how to get into the menu number '7'.
With the key in the ignition, but in the off position, press and hold down the odometer reset button, while holding the button down, switch the key in the ignition to position 1.
The screen will say 'Test' and a number.
Scroll through, (pressing reset button) through to test 19 and wait a moment.
Wait and the message will say "log i-off" then "log i-on" and back to "log i-off" again. When "log i-off" appears, press again. You are now in the system. (Woooo)
You can (if you wish) start the ignition any time from now.
Scroll through to test 7.0 (or whichever from the list below) and wait a moment, after a pause you will enter the test 7.* range of information.
You can scroll through now (7.1,7.2,7.3 etc.) using the reset button.
You can exit each menu by pressing, holding for a few seconds, then releasing the reset button.
To leave the system scroll to 19 and leave it for a few moments.
Switching off the ignition also exits the system.
Test:
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
1.3 Coding-, Diagnostic- and Bus-index
1.4 Production Date (Calender week/year)
1.5 Hard- and Software status
1.6 Injectorstatus, Cylinder count, Engine factor.
2.0 Combisystem Test
3.0 Service intervall counter
4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
4.1 Consumption in liters/100kms.
5.0 Distance consumption in l/100kms.
5.1 Actual rest distance with available fuel in Kms.
6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right
6.1 Total amount of fuel in tank.
6.2 Show value of Fuel guage. 1= both senders OK, 2= sender failure, 3=ti signal unplausible (no reading)
7.0 Actual coolant temp.
7.1 Actual outside temp.
7.2 Actual engine revs.
7.3 Actual speed
8.0 Hexadecimal readings of menu 7.0 to 7.3
9.0 Actual on board voltage (Battery)
10.0 Land codes
11.0 Unit codes
12.0 No funktion
13.0 Gong test
14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures
15.0 - 18.0 No funktion
19.0 On/Off for Test menu.
20.0 Correction factor for Fuel consumption
Formula for correction:
Shown consumption x 1000 / user defined consumption
Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
20.1 Sets 10ths. for consumption factor
20.2 Sets 100ths. and 1000ths. for consumption factor
20.3 Saves the new consumption factor and shows new value
21.0 Software reset. (Same as disconnecting battery)
I apologize for not being able to give credit to the original source for this... I copied it a few years ago, and had it saved a a text file.
Old Dec 11, 2011 | 01:04 PM
fredred's Avatar
fredred
thats what i was talking about
i also found "the list" . more commonly known as ECU RESET PROCEDURE R50/52/53 minis @ mini mania . everyone should have a copy . if you have done any mods you should try this.
thanks for the help.
BadgeFTW
Sep 14, 2015 03:49 PM
Timmy_r53
Sep 14, 2015 01:59 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
Sep 10, 2015 11:55 AM
OutMotoring
Sep 8, 2015 06:27 AM
