Electrical coding folding mirrors
Old Sep 2, 2011 | 07:34 PM
killerfox's Avatar
killerfox
I have power folding mirrors and can fold out mirrors with key fob when unlocking car but they will not fold in when locking. Any suggestions?? I am using v41 datens, 2008 clubman S.
Old Sep 7, 2011 | 05:15 AM
alexs3d2's Avatar
alexs3d2
There are several settings related to the folding mirrors in the FRM module, but none of them function on the R56 because the mirrors are not connected to the FRM.
I wouldn't think the R55 is any different, but if you say the mirrors auto un-fold then something must be different...
Old Sep 8, 2011 | 02:44 PM
GTECKO's Avatar
GTECKO
I do believe alexs3d2 is right, unlike the windows, on the mini you cannot code the mirrors with the fob...it is only activated through the *** on ur door panel.
You can do it on the bimmers...but as far as I read on the modules, not applicable for the Mini (even though the ecu/cpu is similar for a lot of things)
did you get ur car with the pf mirror factory build or you did it yourself ?
Old Sep 8, 2011 | 02:49 PM
killerfox's Avatar
killerfox
They were factory installed. I can get them to unfold with the key fob just not fold.
Old Sep 8, 2011 | 03:09 PM
GTECKO's Avatar
GTECKO
Im looking at the tace file right now, and can't find anything ... it does exist as to be added in the VO, but has of having it on FRM ... can't seem to find it
You should have
SPIEGELABKLAPPEN
aktiv
which (google translated is mirror flipping)
However in the FRM, that is the only thing about it...
Old Sep 8, 2011 | 11:19 PM
alexs3d2's Avatar
alexs3d2
SPIEGEL ABKLAPPEN means mirror folding...
SPIEGEL ANKLAPPEN means mirror un-folding...
Reading through the BMW WDS it does confirm that the FRM should not be connected to the mirrors on the R56. It also says that the mirror glass should tilt on reverse, if the *** is on the correct side, which I believe none has actually seen working. So maybe the WDS is not that accurate afterall...
Old Sep 9, 2011 | 09:57 AM
schatzy62's Avatar
schatzy62
I can fully confirm that the WDS has many errors in it. There a a number of things that are in the BMW WDS that work on the BMW's and it seems they were copied into the MINI WDS and don't work on the MINI. I.E. they took a BLW WDS and modified it for MINI use but missed takeing out all the things that do not work on the MINI.
On my 2008 I wish i could get the mirrors to unfold with the fob but it does not work.
Old Sep 9, 2011 | 10:12 AM
killerfox's Avatar
killerfox
Here is what the FRM module has:
SPIEGEL_HEIZUNG
SPIEGEL_MEMORY
SPIEGEL_BORDSTEIN_AUTOM
SPIEGEL_EINKLAPPEN
SPIEGEL_KOMFORT_EINKLAPP
SPIEGEL_ELEKTROCHROM
I had been able to fold out mirrors previously but since the dealer replaced one I can no longer get them to work with the fob. The do work from the switch inside the car, so I guess since they are not actually controlled by the FRM module we are stuck.
Old Jan 3, 2016 | 10:37 PM
Old Baldy's Avatar
Old Baldy
folding mirrors
Killerfox,
I am a new owner of a 2008 Cooper S. When I got it, the mirrors
would fold and unfold with the fob, or 20 MPH which ever came first.
The GPS kept wanting to go to California.
After about 2 weeks of that, it ask if I wanted to RESET. Being stupid,
I pushed down on the joy stick. It no longer wants to go to Calif..
But the fob no longer controls the mirrors.
The car was manufactured on 02/20/2008.
I can now drive 60+ MPH with the mirrors folded.
They will not fold at that speed. There is a sensor somewhere.
Starting to learn about datems.
Old Nov 17, 2016 | 11:35 AM
Scooter24's Avatar
Scooter24
Anything new with the mirror folding or unot folding with the fob? I have a 2011 mini s and I am trying to figure out if it can be done.
Old Nov 17, 2016 | 03:26 PM
siriuszero's Avatar
siriuszero
From what I've gathered, the only 2nd generation MINIs it works on are the 2013-2016 Countryman and Paceman that have a button the doors that works the powerfold mirrors rather than the ****.
Old Nov 17, 2016 | 03:30 PM
Scooter24's Avatar
Scooter24
Ahhhh bummer. Would be a nice touch if I could have been able to get that coded.
flredmini
Apr 5, 2016 06:21 AM
khumpert
Nov 30, 2015 11:48 AM
StuRat
Aug 25, 2015 05:27 AM
ludedude
Aug 10, 2015 07:16 PM
