Electrical rear fog light
Old Jul 10, 2011 | 05:42 PM
wkp1219's Avatar
wkp1219
rear fog light
have n 06 MCS and have the rubber plug in the center of the rar bumper. I pulled it out and there is a connection behind it for a light, it was taped to the frame obviously because the car didnt come with the option. question is can i install the light fixture and just plug it iinto the exisiting harness? what else do I need?
Old Jul 10, 2011 | 06:20 PM
Eric_Rowland's Avatar
Eric_Rowland
You'll also need a toggle rack with the appropriate toggle, and to have the dealer program the BCM so that it recognizes the fog light.
Old Jul 10, 2011 | 06:27 PM
GreenR53's Avatar
GreenR53
Yep
You'll need the toggle bank and the actual light. I got mine toggle bank and light from Outmotoring.com. Your looking at about an hour of labor to get the BCM coded for the light. BTW the rear fog is great for tail gaters.
Old Jul 11, 2011 | 05:10 AM
wkp1219's Avatar
wkp1219
toggle
I checked outmotoring and couldn't find the toggle bank???
I saw the light but no toggles
Old Jul 11, 2011 | 07:39 AM
GreenR53's Avatar
GreenR53
Sorry forgot to mention you'll need to call him on that toggle bank.
Old Jul 11, 2011 | 08:23 AM
wkp1219's Avatar
wkp1219
is it possible to just buy a new toggle bank cover and 1 togle switch lever to snap into the old toggle bank
Old Jul 11, 2011 | 08:33 AM
GreenR53's Avatar
GreenR53
It's harder to do than you think because the switch doesn't simply just "snap in"
Old Jul 11, 2011 | 10:42 AM
Eric_Rowland
Not that I know of. You could buy just a toggle and drill the cover - that has been done before for aesthetic reasons. Not positive that would actuate the light, but it should. Downside of that is that you don't get the lighted toggle telling you the rear fog is on, nor the graphic telling you what the toggle is for.
If you can source a toggle and money is tight, you can give it a try. If it doesn't work, then get the full toggle rack.
Old Jul 11, 2011 | 01:36 PM
wkp1219's Avatar
wkp1219
just heard back from Outmotoring on the toggle switch panel.....$238.00, does that sound right?
Old Jul 11, 2011 | 02:01 PM
difficulTT's Avatar
difficulTT
You could always buy the light and a kit to make it function as an additional brake light... That's what I did as I found the toggle switch panel to be too expensive.
http://www.gominigo.com/BLK-MINI.html
Old Jul 11, 2011 | 02:42 PM
rkw's Avatar
rkw
Single toggle levers are not available for purchase separately. You can buy a cheap used switch bank off eBay (it probably won't have the full set of 6 toggles) and transfer one of the toggle levers over. There's a thread somewhere describing how to do it.
Old Jul 11, 2011 | 03:45 PM
iceckid's Avatar
iceckid
Another option is to use the spot and wire in another brake light, or a third reverse light, then you dont need to purchase a switch.
Old Jul 11, 2011 | 03:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I have a good used full toggle panel out of a wreck for $100, just email me if you want it. Just took it out this week.
WAY
info@waymotorworks.com
Old Jul 11, 2011 | 07:25 PM
HRM's Avatar
HRM
I use the gas pedal for that.
Old Jul 11, 2011 | 07:44 PM
GreenR53's Avatar
GreenR53
Originally Posted by waymotorworks
i have a good used full toggle panel out of a wreck for $100, just email me if you want it. Just took it out this week.
winning!!!!
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
Aug 7, 2015 05:56 AM
