Electrical Bluetooth OBDII Connector- Anybody tried?
well i got the ELM327 and i cant get it to link up with my EVO HTC... :( i might be doing it the wrong way but when i connect it to the OBD2 port i get a red light and i downloaded :TORQUE" to my phone and still not linking up!!!! anyone else knows what settings i need to have my phone at? thanks in advance!!!!
We get in a lot of them that just do not work at all, we have to test every unit.
Not sure if this is relevant..But i just found this.
"*PLEASE NOTE!* Any reports of hanging or reboots after quitting the app is due to a bug in HTC devices and Galaxy Tab,this can be triggered by using the Pandora app. Disabling Pandoras new bluetooth settings fixes the problem, but HTC/Samsung need to release a fix. Please contact their support and request a fix, Thanks!"
Also does anyone know if it can monitor transmission temps???
I am pretty sure that the R56 will not show Trans Temp on Torque.
I may be way off but...what about on 2007 Sprinter van diesel any ideas i can not see it anywhere...i am hoping to use it on both vehicles (R60)
i will be ordering my phone bracket from you next week .. when my countryman gets here :-)
I don't know if Van Diesel will give you Tranny Temps, but the OBDII should work just fine in general. It does seem more likely that the ECU on the Sprinter is tracking the trans temp.
If you need a phone mount for the van you could try;
http://www.cravenspeed.com/products/The-Belmont.html
http://www.cravenspeed.com/products/...nting-Kit.html
With the Belmont we could swap the gauge cup for a phone mount. The other mount has proven to fit a variety of trucks and SUV's, maybe it will work on your Sprinter.
thank you for the links..
i know the tranny temps show up on the scangauge 2 so i assume it should work.
thanks again
thanks again
gar56
Nov 15, 2016 06:41 AM
