Electrical new owner, HID problems help!
Old Aug 7, 2010 | 09:58 AM
nlanderson's Avatar
nlanderson
i've just purchased a 06 cooper S, my first mod was getting rid of the halogen headlamps and replacing with projector HIDs, after installing the bulbs and starting the car, the HIDs would only stay on for around 15-30 seconds then they'd flicker off. So plan B I purchased the Error Code Eliminator from DDM tuning which was suppose to trick my computer into thinking it was getting the same amount of wattage. Once I hooked that up only ONE HID worked the first time i started it, then the second try I got nothing. What is wrong??! help me out here!
Old Aug 7, 2010 | 10:54 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is this an OEM Projector HID assembly or a halogen projector assembly with an aftermarket HID kit ?
If it's an aftermarket kit, in some cases, you have to reverse the connector for the wires + - which attach at the top of the ballast. Could be after re-assembly you plugged it in differently than before.
Old Aug 7, 2010 | 12:15 PM
JustinGTP's Avatar
JustinGTP
If you have replaced the halogen lights with the OEM factory projectors + HIDs, you need to have the dealer or someone with the BMW software to program your car so it knows it has HIDs.
If you have an aftermarket kit, sometimes you need a wiring harness to properly supply the HIDs with enough power. I don't recommend aftermarket kits due to improper alignment, too blue, less light output, blinding, hot spots in lighting, illegal, etc etc.
Toolman
Jan 20, 2016 06:50 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
R53Mom
Aug 17, 2015 01:38 PM
AZN Optics
Aug 16, 2015 11:52 PM
