Electrical Lighter Socket Replacement
Old Aug 14, 2009 | 11:35 AM
Diploman's Avatar
Diploman
The lighter socket in my 07 MCS has shorted out - blows the fuse whenever I try to use it. I need this power outlet for my GPS. Currently I am running a RadioShack extension cord from the rear power outlet as a work-around.
The OEM outlets are regrettably cheap and flimsy, easily deformed by repeated plug insertions. Bean counters obviously prevailed when BMW chose the supplier for the power outlet plugs. I would like to replace the flimsy power outlet plugs - both of them - with heavier-duty, more reliable items.
Would appreciate advice/suggestions on where to source more substantial power outlet plugs, as well as installation tips. Thanks in advance.
Old Aug 14, 2009 | 02:08 PM
ron-s mini's Avatar
ron-s mini
I would lift the console and look for a short (wires touching together or anything else).
The Mini should not blowing the fuse with that small of a load. Have you tried another extension cord to isolate and insure that is not the problem?
Old Aug 14, 2009 | 08:45 PM
kukaepe's Avatar
kukaepe
I had a similar problem and after replacing to many fuses I discovered a dime, yes a $0.10 coin, in the bottom of the lighter socket. What are the chances of that happening? I doubt this is your problem but it might be worth looking down into the socket to see if you've got something down in there making trouble.
DixonL2
Apr 13, 2021 08:05 AM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
FLYM1N1
Aug 16, 2015 01:17 PM
minipopkart
Aug 13, 2015 05:22 AM
