Electrical 05-06 Key Programmed to an 03?
Old Feb 21, 2009 | 10:51 AM
not-so-rednwhitecooper
Well, i'm in kinda of a wierd mood, I have been doing a lot of cheap, unusual mods lately.
I'm wondering, will a 05-06 key mesh with the pre-04 programming? I like the newer key more than the old key. I was thinking of just buying one on eBay and opening it up to see how similar they are.
Anyone ever ask a dealer if they will try and do the programming?
Old Feb 21, 2009 | 01:16 PM
UKSUV's Avatar
UKSUV
This is a gray area....the kep has to be synced with the EMS and GCM. They ask for a VIN since they are VIN specific...just like the ECU. If you are real nice they could hook you up. Especially if its to your 03. They arent supposed to recode from one VIN to another....
Old Feb 21, 2009 | 01:22 PM
I'm just wondering if the electronics will sync. Since the cars use CAN, I imagine it wouldn't be that big of a deal.
I only had my 05 for a year, but I really liked having a hatch button right on the key.
I think I could talk them into it somehow.
Old Feb 21, 2009 | 02:02 PM
UKSUV's Avatar
UKSUV
I dont see why it wouldnt work. The only thing is if the "hatch" function would work. Might as well try and find out!
Old Feb 21, 2009 | 02:18 PM
I'm just gonna buy a used key, swap over the cut key and the RF chip from my second key and see if I can talk somebody at Classic into helping me out.
Old Feb 21, 2009 | 02:31 PM
camminich's Avatar
camminich
It takes a bit to make this work, more than just a key program. To do so you need to replace the module located behind the bonnet release, and as soon as that is done, the accelerator pedal will no longer work, so it will need to done by someone that can also do the key reporgramming.
I would imagine most dealers would shy away from doing this.
Old Feb 21, 2009 | 02:42 PM
Why does the car need a new BCM? The car only has 2 keys programmed, so I should be able to program up to 8 more before I need a new BCM.
Old Feb 21, 2009 | 02:53 PM
camminich's Avatar
camminich
I am not sure 100% why, but the part is different between the 02-04 and the 05-06, and I would say that is probably it.
I helped do a swap from an 05 parts MINI to a 04 and since we did not have the luxury of doing the repogram, we had to swap everything out. Box, pedal, and ignition switch. Didn't do the door handle, but then how often do you actually need that.
Old Feb 21, 2009 | 03:49 PM
rkw's Avatar
rkw
They will certainly be different and it would be hard to learn much by looking inside the keys. The keys have different circuit boards because the buttons are different and repositioned, and the newer key has circuitry to recharge the battery (which is not meant to be replaceable). My '06 Owner's Manual doesn't describe how to open the key and the case doesn't have a slot to facilitate prying.
Without knowing what MINI actually changed along with the newer key, there are unknown compatibility issues. Did they change the transmitter/receiver at all (does the transmitter in the new key work with the receiver in the older car)? Do the new and old keys use compatible security smart chips? Operating the remote boot unlock is performed through the computer, but the feature might not be included in any of the software versions available for your model year / VIN.
Old Feb 21, 2009 | 11:05 PM
UKSUV's Avatar
UKSUV
Thats not correct. There is no module for the bonnet release. The actuator for the bonnet is controlled by the BCM. If the key sends the signal to the BCM to open the hatch....the car will do so. But it has to have the capability in the line of code to do so in the BCM. If it doesnt work....anyone who has cracked the Mini's language should be able to add the lines of code. And the accelerator works just fine with the hatch popped....ask AZBlackout....LMAO
Old Feb 22, 2009 | 08:40 AM
camminich's Avatar
camminich
I was refering to where the module is, not what it does. Open up then panel where the release is located, there is a module back in there.
Old Feb 22, 2009 | 10:15 AM
UKSUV's Avatar
UKSUV
My interior is gutted so I know exactly where everything is and what it looks like. I think we are saying the same thing....yes...you could reference it as a MODULE...you need something to take the electrical signals and convert the energy ...but thats not where the signal initially goes through to pop the hatch. Its the BCM. Regardless...that doesnt need to change. The different part number is to reference a TSB about 5 years ago....
bahman
Feb 14, 2016 10:29 AM
newminijcw
Oct 21, 2015 02:37 PM
pahg
Oct 5, 2015 11:50 AM
tcjake
Sep 30, 2015 08:14 AM
jennster
Sep 28, 2015 06:19 PM
