Electrical Is the MSD coil frying my Iphone
Hi guys,
I finally decided to turn to the community in order to get a lead.
I had an MSD coil install on my car about a year ago, never had any problems with it. Since I've had it, I've notice my radar detector's alarm (passport 8500 X) behing triggered systematically on hard acceleration. Didin't make a big deal out of it. Until I had my engine rebuilt this summer, in the process my alternator was rebuil. The battery now delivers about 14V (according to my ScanGuaugeII), but here is the catch: in the past month I went through 3 iPhones!!!. Common denominator? I charged them on board using the lighter power outlet. I would plug the phone on a long trip, charge the phone, next thing you know the phone is dead. Thank god the Apple store changed them, no question asked. Only after I read couple threads about the MSD that I wondered if there was anything wrong with it. The mechanic at Boston Dyno told me way before this hapened that many people had problem with MSD coils. I personally never had any issues until those successive iPhone mishaps, that's the only thing I can see.
Question
: has anyone ever experience this phenomenon?
How did you deal with your misfortune? Any idea for a way to fix it?
Your help would be greatly appreciated.
Sorry for the long post.
Stay strong, safe and happy motorers.
Frenchy.
Question
: has anyone ever experience this phenomenon? How did you deal with your misfortune? Any idea for a way to fix it?
Frenchy.
I dont see a way that can affect your charging. There is a voltage tolerance for the Iphone. I dont think 14vdc would do it...
. I would say a shorted wire could cause it but you would know if you had a circumstance like that. Maybe the regulator in the General Control Module isnt doing its job and killing it...
But thanks for your insight it is certainly helpfull.
cheer up,
Frenchy.
That may be your problem. Try using an Apple charger and see if your problem goes away. I never believed in an aftermarket charger causing problems to a phone until it happened to a friend of mine and it was later explained as to why it occurred. Don't ask me to explain it as I have forgotten the rationale behind it.
The cig lighter is relatively quite...
if back emf from the coil were coming throught the electronics, you're iPhone would be the least of your problems. I agree with the post above that says try the Apple charger.... Really, the voltages aren't much of an issue.... The circuites in the iPhone run on much lower voltages than the car battery, and there are internal electronics that regulate the voltage to what's needed (as well as govern the charging of the batteries).
Matt
Matt
5, 14, 28, 115, 1 googleplex...Im just saying that something isnt regulating properly whether its the Belkin charger (most likely) or the Mini's electronics....SUCKA.
Some assemblies have a .01 volt tolerance sometimes. Im sure the Iphone isnt one of them but just sayin.
Cars nowadays suck since they started to get into the CAN-BUS and HEX-CAN bus applications. Better for tuning but definitely not for troubleshooting if u dont have the right diagnostic equipment or clue...
I have an Iphone 3G and the MSD coil. I regularly charge my Iphone in my car using the Belkin car charger, which AT&T sells and recommends for the Iphone 3G.
No problems at all. Granted the charge doesn't seem to last as long, for some reason, when the Iphone is fully charged in the car as when it is fully charged at home but I'm told that's an issue with the Iphone not the Belkin charger.
I'd talk with your AT&T agent first, Belkin next, and then throw that MSD in the river next.
I agree the range of voltages in a car can get as low as 9v during cranking for start up to as high as 16-17v before the over voltage relay kicks in a shuts the alternator down.
Most car batteries are 6cell with 2.1v per cell...a brand new battery should show 12.6v Alternators are set to run a certain voltage typically ~13.6-14.2v and this is controlled by the voltage regulator (varies electrical current in the magnetic field with the speed it rotates to keep everything constant).
Your coil pack really should have nothing to do with the charging system as it is only connected via those few small wires...unless you have quite a few bad grounds on your car it should be no problem. But it should have nothing to do with your MSD.
I 5th using an Apple OEM car charger. Even if AT&T recommends the Belkin I would have a feeling something is wrong with your unit. And personally I believe in using OEM charging equipment your case in point.
I seriously doubt it is the coil. Hook a multimeter up to you 12v accessories plug, take voltage and current readings at idle then punch it and watch again. It really sound like your car's charging system is spiking.
Your coil should not produce any backwards current, I say should not be cause it is electricity as soon as you say something can't happen it does.
We had a problem a few days ago to where a relay was bleeding voltage to the other side of the power/control circuit to where the relay was robbing voltage from an unrelated system. So whenever you disconnected a certain lead....your voltage would return....
Stooopid diode and zener diodes/ Nothing but trouble I tell ya. Not to hijack this thread but I had to vent somewhere...
APPLE does not make a car charger for the 3G iphone.
No need to look for one - it doesn't exist!
AND - the iphone is very specific as to which chargers it will accept, not just any ipod car charger or even for older iphones.
I hope you purchased the Applecare for your iphone - they may be willing to help you if you did.
fkrowland
Sep 30, 2015 10:30 AM
