Electrical damn firewall.
Old Oct 1, 2007 | 06:47 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
damn firewall.
I cant get my 3 small wire throught the firewall...any other ways? tips? seriously the most agravating thing ever....plEASE HELP ME
Old Oct 1, 2007 | 06:58 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Over near the master cylinder there is a big rubber grommet where the wire harness comes through, take a razor blade and cut a small slit in the grommet close to the sheet metal. Tape your wires to a straightened out wire coat hanger or something similar and push it through the slit you made in the grommet. Go under the dash and your wires will be there.
Old Oct 1, 2007 | 07:03 PM
RA080624's Avatar
RA080624
coat hanger +1
Old Oct 1, 2007 | 07:04 PM
MNEEME's Avatar
MNEEME
Weed-Whacker Line! Worked for me. Buy orange or other bright color and its easy to pick out in a mess of wires!
Old Oct 2, 2007 | 03:30 AM
davavd's Avatar
davavd
I needed to go from the inside out, more difficult because you can't see the grommet and get to it at the same time. I found a piece of 3/16" aluminum tubing about 4" long in a box of miscellaneous parts, crimped one end into a sort of point, jammed my wires into the other end, and was able to push it through the grommet from under the dash. Good Luck.
Old Oct 2, 2007 | 09:35 AM
Bahamabart's Avatar
Bahamabart
no biggie - I taped a line (fishing line ) to a long screw driver and pushed it thru the grommet referenced from the engine bay side. I then deattached the line from under the dash, attached the cables I wanted to pull, returned to the engine bay and pulled the wires thru. Yes I really ha dto put pressue to puncture.
Another option - I took a toe nail clipper (scissor type) and from under the dash was able to cut a slit. I then pushed a coat hanger from under the dash.
PS - no matter how you do it - aggrivation is guaranteed.
Filmy
15
Jun 6, 2023 06:27 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
Systemlord
Sep 19, 2015 02:57 PM
IrishMCS
Sep 15, 2015 05:43 AM
sempaipaul
Sep 9, 2015 05:55 PM
