Electrical Where did i go wrong (Sirius S10 install)
Old Sep 19, 2007 | 09:06 AM
daveag98's Avatar
daveag98
Well i tried to figure it out and have had no luck.
Here is the problem.
I tried to install my S10 with car dock kit into my 07 mini, using the add a fuse and fuse 21 list on another thread.
Here is how i started. I cut off the cigarette plug and then did not know which wire was positive and which was ground (I am sure this was my first mistake), One wire has a dash white line and the other wire has writing on it.
(thinking the writing wire is the positve) I hooked it up to the add a circuit (fuse 21 using a 10amp on both the 21 and add a fuse ) and the ground to a screw next to the golve box when the glove box is open.
Result the unit starts to charge but the car dock does not come on , it does however get warm. I wire the cig plug back on to test it and it works fine.
Where did i go wrong and what can i do to make it work?
I know its a small step i have to be missing or something i am not thinking of or doing correctly. I am really close to taking it to an installer but i know being this close its just a matter of doing one extra step to get it working.
If needed i can provide pics of everything.
Old Sep 19, 2007 | 05:09 PM
crash13's Avatar
crash13
Check the output of the cigarette lighter adapter (should be printed on the side). Many units are not 12V.
Old Sep 19, 2007 | 07:15 PM
a96bimmerm3's Avatar
a96bimmerm3
I blew up a dock a while ago because there was a resistor and stuff in the cigarette lighter... turns out it was a 5v dock and not a 12v.
Old Sep 19, 2007 | 07:44 PM
Coffeeman's Avatar
Coffeeman
This is correct, the unit is 5volts, bypassing the lighter plug that comes with the S10 will blow up the S10, if connected directly to 12 volts DC.
Old Sep 20, 2007 | 06:32 AM
daveag98's Avatar
daveag98
Should i replace the cig lighter adapter and just wire a female adapter from radio shack?
Replace is not the correct word, as i would most likely buy a new one and even have to replace the dock.
Old Sep 20, 2007 | 07:42 AM
Coffeeman's Avatar
Coffeeman
Yes, I think that this would be a good idea. If you are mounting the Dock in the center stack cubby, there is room under the heater (behind the center stack) to tuck the cig. lighter adapter.
Old Sep 20, 2007 | 07:58 AM
daveag98's Avatar
daveag98
Thanks Coffeeman, looks like i gotta go to radio shack and best buy, that 5 dollar warrenty for the car dock might come in handy
Old Sep 21, 2007 | 08:14 AM
daveag98's Avatar
daveag98
I went back and wired the whole thing back together, the car dock still works although i am sure some life has been lost off it.
Thanks for the help, next time i will learn to read
Old Sep 21, 2007 | 08:18 AM
Coffeeman's Avatar
Coffeeman
Glad to hear it. I've noticed that the Sirius lighter plugs are really cheaply made, and the center conductor "button" snaps off easily. You may want to keep an eye on it. On mine, I opened up the adapter, and soldered + & - wires directly to the circuit board.
Old Sep 21, 2007 | 09:35 AM
daveag98's Avatar
daveag98
thanks Coffeeman, i will follow on that, i would hate to get everything installed then have to tear it out for something dumb like that.
Old Oct 15, 2007 | 09:22 PM
DyeLooper's Avatar
DyeLooper
What is fuse 21? F21 10A 30G X11003 6 0.75 RT/GE MINI Joystick
MINI JOYSTICK? What is this?
Old Oct 29, 2007 | 10:14 AM
spfdhed's Avatar
spfdhed
BTW, on "myradiostore" you can get a hardwire adapter that will work with many satellite head units and therefore you don't have to use a aftermarket cig plug which may cause issues with ground loops, and in my experience, are not very well made.
Old Oct 29, 2007 | 10:29 AM
djam43's Avatar
djam43
The Mini Joystick is the remote control lever that is on the gearshift console that controls all of the functions of the Nav/ radio unit for those who have NAV.
Old Oct 29, 2007 | 10:38 AM
DyeLooper's Avatar
DyeLooper
Tx, I did use fuse 21 afterall. I do not have NAV.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
dpcompt
Aug 12, 2015 07:39 PM
