Electrical Mini Cooper Light Diagrams
Old Jul 5, 2007 | 07:16 AM
jcraig's Avatar
jcraig
First of all, hello everyone! I just bought my first MCS this Monday and I am in love! My first order of business is to replace a few bulbs. My drivers side front parking light is burnt out so I went down to Autozone to get a replacement. Well, it turns out that A.) There was no bulb in place at all, and B.) They sold me the wrong bulb.
Ok, so I even looked myself online at the Autozone website and can't figure it out. Our car has so many lights and they are named all sorts of different names depending where you look (ie. Cornering light, parking lamp, driving light, etc.). So, I guess the best way is to just show you which one I need;
In this photo, it's the clear bulb, the smaller one, not the orange turn signal. I assumed this was called the "Parking Light" since it's what illuminates when the parking lights are on. However, Autozone's part# for "Parking Light" is; 2825. That's a no-go.
I've searched the forums and from the best I can tell, I think it's supposed to be 7506? But, according to the pictures of that bulb, the connectors don't look right.
So, perhaps there should be a diagram posted of all the stock light Part#'s for each car. I am more than happy to Photoshop some diagrams for each model (R50, R53, R54, R55, R56, R57) if anyone can help find good front/rear photos for each model.
R50, R52, R53 - Front
1. Headlight (Low Beam) - H7 or Xenon
2. Headlight (High Beam) - H7
3. Side Marker - 194
4. Parking Light - 194
5. Turn Signal - 7507
6. Fog Light - H11
7. Fender Light? - 194
R56 - Front
1. Healight (Low Beam) - H7 or Xenon
2. Headlight (High Beam) - ?
3. Turn Signal? - ?
4. Parking Light? - ?
5. Fog Light? - ?
6. Side Marker - ?
Note: Please post links to better images and I will make a diagram for each one. Thanks!
Old Jul 5, 2007 | 12:52 PM
jcraig's Avatar
jcraig
Any help identifying the names and part #'s of the bulbs in the photo's above would be much appreciated. Thank you!
Old Jul 5, 2007 | 01:43 PM
MiniTron's Avatar
MiniTron
What year is your MCS? I can only answer for the R50/52/53.
2. High beam headlights are H7 just like the halogen low beam.
4. The white bulb for the front parking light is a 194.
5. Front turn signal is 7507.
3, 7. Side repeater and fender lights are also 194's.
I do know that on the new R56's the Xenon's are Bi-xenon so you only have one bulb for both and the difference is done by a moving lens or reflector.
Old Jul 5, 2007 | 07:35 PM
minjae's Avatar
minjae
wow i was just thinking about making a thread just like this one. you should add the rear lights too.
and mods should sticky this. seeing how i searched for about an hour or two looking for all the bulb sizes..
but everything wat minitron said. i only know those light bulb sizes. and r56 ones i have no clue.
great list tho. and great illustrations. indeed helpful.
Old Jul 6, 2007 | 05:51 AM
jcraig's Avatar
jcraig
Thanks guys! I thought I was the only one who was having trouble finding a simple diagram.:impatient
I went back to Autozone yesterday and looked through every single bulb in the isle. And yes, I finally figured out that the parking light is a 194. Autozone's Part # (2825) is wrong! This bulb does work but it's too small, and does not properly seat in the bulb holder.
My Mini is an R53 BTW. I'll update the original post with the proper Part #'s.
Old Jul 6, 2007 | 05:53 AM
hailpurdue's Avatar
hailpurdue
The parking light is not a 194, it's the euro equivalent, the reason I mention it, if you buy 194 led's, they will not work. Found that out the hard way.....
Old Jul 6, 2007 | 06:19 AM
jcraig's Avatar
jcraig
That was my next question. I saw the JamStrait LED bulbs (194) but noticed the diameter of the 4 LED's was much larger than the normal incandescent bulb. So, these will not fit?
I opened more bulb packages than Autozone cares to allow, and the 194's were the closest bulb I could find to the stock parking lamp. The 2825 bulb was shorter, and the base is not the same. It will seat in the holder but will move side to side and up and down. I brought the bulb holder into the store and tried it out.
I went with the amber (orange) 194's for parking lights ($2.99), but I think I am going to look around online for a silver lens to avoid the fried egg look, and maybe look into something a little higher wattage to look more like a daytime driving light. I think Sylvania has a Silverstar halogen that might work. Anyone know the max wattage I should stick in the parking light? I may need to run a larger amp fuse if going with a higher watt bulb. Any issues anyone can see with this?
Also, anyone know a good source/brand for the H11 fogs? I want to change them to either A.) Xenon match, or B.) Bright Yellow.
Old Jul 6, 2007 | 06:35 AM
jcraig's Avatar
jcraig
Hmmm... now I'm looking directly on the Sylvania site and they say the parking light is a 2825 as well. I wonder if the different brands are slightly different sizes. Because I KNOW the cheap Autozone 2825 bulb was a terrible fit, while the 194 was perfect. Just try a few out, you can always return them!
Here's what Sylvania has on thier site (R50, R52, R53 w/ Xenon);
Low beam headlamp
HID-D2R
High beam headlamp
H9-65W
Parking light
2825LL
Front turn signal
7507A
7507AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Rear turn signal
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7528
High mount stop light
Assembly
Fog/Driving light
H11-55W
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
2825LL
Dome light
6418
Step/Courtesy light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Notice they list H9 for the High Beam Headlight, not H7!?
Old Jul 6, 2007 | 06:44 AM
hailpurdue's Avatar
hailpurdue
The LED 194's did not fit (4 lights)
The regular 194's I didn't try, but they are not an identical match. we checked. I ended up paiting them silver instead of paying BMW 15 each. And they look great.
For the interior, 194's are fine (not in the overhead, but puddle/ boot/ glove/ footwells all fit 194's just fine)
Old Jul 6, 2007 | 06:48 AM
minjae's Avatar
minjae
i was actually thinking about going with the led's for the 194 bulbs parkin lights from autolumination.com
and then to answer you question about fogs for xenon match..you can go to this website ( im buying h7 and 194 bulbs from them )
http://www.hoen-usa.com/fog.htm
and
http://www.hoen-usa.com/city2.htm
and then some people were talking about this site. (the yellow bulbs are much cheaper than the one on hoen. but then again people say hoen is very good but they also say this website is good too)
(uh..let me find the other website first. haha)
Old Jul 6, 2007 | 10:22 AM
rkw's Avatar
rkw
Did you mean that they were too large to fit the opening for the bulb? Some 194 LEDs are wider than a standard bulb and will not fit in all locations, but others are very compact and completely compatible. There are many designations for the same thing, and 194 is the same as euro equivalents (W5W, T10, 501, etc).
Old Jul 6, 2007 | 10:32 AM
rkw's Avatar
rkw
By the way, the 2007 R56 Owner's Manual lists bulb types for exterior lights (the manuals for earlier years do not).
Old Jul 6, 2007 | 10:34 AM
hailpurdue's Avatar
hailpurdue
That's correct. Just the side markers.
Old Jul 6, 2007 | 01:29 PM
MiniTron's Avatar
MiniTron
I have the 4-led 194 equivelant from Jamstrait (they work great in that application BTW) in my side repeaters, and they fit just fine. I don't know about the parking lights though. I just changed mine out for the angel eyes units from mossmini.com. The bulbs that came out look like clear 194's.
Old Jul 6, 2007 | 06:31 PM
minjae's Avatar
minjae
http://www.supremepowerparts.com/products/bulbs.aspx
there's the other site for the yellow fog bulbs.
Old Jul 15, 2007 | 04:59 PM
raul's Avatar
raul
Hi.
Does any one know which bulbs goes in the Side Markers of a Bmw 530i 2004?
I've checked in the sylvania site and it says the 2825, but i want to be shure if that's the correct bulb type.
Cheers.
Old Jul 16, 2007 | 07:14 AM
jcraig's Avatar
jcraig
I've learned that the 2825 is the same as a 194 or a W5W. I would use the 194 as it has been a better fit in my experience.
If anyone is interested, I can update the diagrams at the top of the post with the correct info we have managed to gather here. Please post the '06-Present info if you would like those diagrams updated as well. Also, if anyone has better photos, I can update that as well.
Old Feb 5, 2011 | 10:38 PM
tydude789's Avatar
tydude789
yes, please post the update diagram for the R53
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
