Rennline Skid Plates - MINI Cooper
ECS Tuning
Rennline Skid Plates For Your MINI Cooper
Known worldwide primarily for their creative and original Porsche offerings, Rennline Inc. is not only the distributor, but manufacturer of the majority of products that wear the Rennline name.
Speed bumps, potholes, and the occasional “off-track” excursion can cause serious damage to critical undercarriage components. The Rennline Aluminum Skidplate is the best-designed solution to the problem.
While this gorgeous addition is rarely seen by onlookers, the peace of mind that comes with this expertly-engineered measure of protection brings more than enough satisfaction.
Fits;
MINI Cooper
R50-R53
R55-R59
F55,F56
"Click HERE to shop Gen 1-Gen 3 MINI Cooper Skid Plates"
With air chunks on the road, this is a little more protection.
Yep, they did that for strength. You could always mod it yourself.
Not really that much, they need the service work these days for MINI so they will drop it and change it.
That sounds like either inaccurate information or bad advice, I can't figure out which.
There are plenty of holes in that hunk of sheet metal, so it doesn't seem like it should compromise strength to move a few around to accommodate routine maintenance. I used to have a skid plate on my Jetta, that had a metal cover that screwed in to allow maintenance. Paid for itself more than once, not because I lowered the car, but because of where I took it and road debris.
Hello,
That's what they told me in the design as we are direct with them. But people always on NAM like to mod and do their own thing on the forums. Just giving them a heads up on why it was that way.
Then Mods to make service holes would be bad advice if it's true and doing so will reduce the integrity of the product. These cars aren't already enough of a PITA to work on without adding to it. That said, a beefed up skid plate can be well worth the price paid if you find yourself bottoming out from time to time.
PelicanParts.com
03-04-2016 03:39 PM
PelicanParts.com
03-04-2016 02:37 PM
06-08-2015 12:18 PM
06-04-2015 03:21 PM
