:: ECS Tuning :: Catch Cans & No Holes ?
Old Apr 14, 2016 | 02:14 PM
ECS Tuning
ECS Tuning and Aftermarket Catch Can Options
Modern day emission regulations require the use of a closed PCV / Breather system to recirculate combustion blow-by gases for cleaner operation and to reduce greenhouse gases.
However, due to inefficient capturing of oil particles within the air charge, a dense amount of oil vapor is allowed to be ingested within the intake tract causing deposits of carbon buildup at the intake ports, back of intake valves and oil deposits within the intake plumbing.
All will eventually lead to poor performance, reduced fuel economy and a decreasing octane rating.
Click HERE for R50 R52 R53 2002-2008 MINI Cooper
Click HERE for R56-R59 & R60 R61 2007+ MINI Cooper
ECS Tuning
Go MINI Go = GMG Motorsport : No Holes License Plate Bracket Kit
Why would you drill holes into your perfectly good front bumper?
Avoid drilling holes in your bumper by utilizing a tow hook mounted plate bracket from GMG! The No Holes License Plate Bracket does not require you to drill into your front bumper. Instead, it utilizes a custom machined stud that screws into the tow hook receptacle.
Simply add or remove your license plate without ever damaging your car.
Click HERE for R50-R59 2002+ MINI Cooper
quickcoop
Dec 4, 2020 09:05 AM
mickymow
Feb 29, 2020 03:40 AM
HaveATank
Mar 17, 2016 08:50 PM
Bglad
Mar 17, 2016 05:36 PM
vtt316
Mar 15, 2016 07:35 PM
