Drivetrain Need more burble/pop
Old Apr 15, 2007 | 03:03 PM
JustJAY's Avatar
JustJAY
Hey all, I have an '04 MCS w/Miltek Catback. I would like to obtain more burble and pop. Does anyone know as to how I can do that? TIA
Old Apr 15, 2007 | 03:07 PM
Scavenger's Avatar
Scavenger
Get the Dinan exhaust! Your test drive of my car Friday certainly confirmed the crazy "pop pop" in this exhaust
Old Apr 15, 2007 | 03:10 PM
ScottRiqui's Avatar
ScottRiqui
If you're willing to live with increased sound levels, removing the resonator (not the muffler) from your exhaust will increase the volume of the popping/burbling. The pops/burble are always there when you decelerate - how much of them you hear and how loud they are is a function of your exhaust system. I don't think it's possible to selectively enhance the burble without an overall increase in noise level.
The exhaust on my car is 2-1/2" from the cat back to a single small muffler (about 7" by 7" by 3"), and then out the back of the car. It's probably louder than most people would like, but the popping/crackling on deceleration sounds beautiful. I'm about to have my muffler shop cut out a section of the exhaust pipe and put flanges on the cut ends so that I can swap a resonator in and out of the system whenever I want to, since the exhaust does drone pretty badly on the freeway.
Old Apr 15, 2007 | 03:12 PM
Bahamabart's Avatar
Bahamabart
Try "Burble in a CAN" sold by Palo Uber.
Old Apr 15, 2007 | 03:22 PM
JustJAY's Avatar
JustJAY
Isn't the resonator the catalytic converter? If so, won't that send an SES and if so, how do you get rid of the SES because I have heard that putting a different/dummy O2 sensor doesn't work.
Old Apr 15, 2007 | 03:27 PM
slag1911's Avatar
slag1911
Yep, Uber patented "Burble in a CAN"
Old Apr 15, 2007 | 03:28 PM
ScottRiqui's Avatar
ScottRiqui
No, most systems have both a resonator AND a muffler, both of which are behind the catalytic converter. On the factory exhaust, the resonator is the muffler-looking thing on the passenger side, and the actual muffler is the one on the driver's side. If you've read about the "one-ball" exhaust mod, all that involves is bypassing/removing the factory resonator.
On the Milltek, the resonator is the cylindrical canister right behind the catalytic converter.
Old Apr 15, 2007 | 03:33 PM
JustJAY's Avatar
JustJAY
Very cool, thanks
Old Apr 15, 2007 | 03:43 PM
ScottRiqui's Avatar
ScottRiqui
And since your resonator attaches directly to the cat, it would be easy/cheap for a muffler shop to replace it with a piece of straight pipe and three flanges. If you didn't like the sound with the resonator removed, you could put a flange on the other end of the resonator and swap it back in place of the straight pipe.
Old Apr 16, 2007 | 12:33 PM
chows4us's Avatar
chows4us
His car is an 04, not an 05/06. I thought on motoringfile an article said the burble was ECU programming? Now when I switched from a JCW exhaust on a 04 to Borla race, it had a tiny bit of burble but still not anywhere near an OEM 05.
Old Apr 16, 2007 | 01:07 PM
Super Coop's Avatar
Super Coop
I put a JCW exhaust on my '05 MCS - burble and pop are a lot less than it had with the stock exhaust.
Old Apr 16, 2007 | 01:18 PM
ScottRiqui's Avatar
ScottRiqui
I think the ECU programming was to enhance/amplify the burbles & pops, but from his original post, it sounds like he's getting a little bit already with his Miltek. I figure that if he's getting any at all, he'll get more with the resonator removed. I don't know how the Miltek sounds with the resonator removed, but he'll still have the dual mufflers, and removing the resonator is both cheap and easily reversible.
Old Apr 16, 2007 | 03:07 PM
JustJAY's Avatar
JustJAY
I do get a tiny bit, but want more. Scavenger has an '06 with a Dinan exhaust and his burbles/pops pushing the clutch in to shift and letting off the accelerator. I really like that and would like to get it to that point.
Scavenger, can you put up an audio clip of it please.
Old Apr 16, 2007 | 03:19 PM
herbie hind's Avatar
herbie hind
get a header . or fold the rear seats down .
Old Apr 16, 2007 | 03:29 PM
Steve_LV's Avatar
Steve_LV
I got a pulley, intake, and exhaust (Milltek) all installed on the same day at AMVIV. I then got the JCW flash for my ecu, and I've got more burble than I ever did before on my '05. I used to just get it at low speed, now I even get it on the freeway when I back off the throttle. It must be in the JCW programming.
Old Apr 16, 2007 | 03:33 PM
Scavenger's Avatar
Scavenger
I'll have to figure the best way to record it
Old Apr 16, 2007 | 06:02 PM
Beecher's Avatar
Beecher
my friend has an 03 JCW, not sure what flash he has, but with OBX 4-2-1 header and OE cat he gets alot of burble pop, when i was following him one day i heard it with my windows down and sunroof open. Not loud, but sporty, really really nice. If you dont want to drop the 200 on a header, just take the pre cat out of the OE system, i hear that has really good results, run a search for clarification if need be on the operation im talking about
hope this helps
Beecher,
Old Apr 16, 2007 | 07:32 PM
JustJAY's Avatar
JustJAY
I don't have back seats to fold
hope this helps
Beecher,
You know, perhaps it is a header thing. I don't have one, so that is next on the list. Thanks everyone for posting
Old Apr 16, 2007 | 08:12 PM
markldriskill's Avatar
markldriskill
I had the Milltek cat back only on my '04 for several months. I then installed an OBX header (from Helix with an OEM cat welded on it -- and I got it ceramic coated at the same time.) Now it has just what I was looking for in the burble area. I turn the radio off and roll down the windows to go through underpasses and tunnels. Sweet music.
Old Apr 16, 2007 | 08:15 PM
Maxicooper's Avatar
Maxicooper
May be I'm crazy, but seriously, I heard more burble/pop after I have my GP IC on.
Old Apr 16, 2007 | 10:19 PM
Guest's Avatar
Guest
You should know, it may have more to do with the fact that your car is an 06 than the exhaust types.
2005 & 2006 MCS's are tuned to have more burble and pop (The ECU actually dumps fuel on lift to make the car burble more)
http://motoringfile.com/2005/06/28/exhaust_popping/
Old Apr 16, 2007 | 10:21 PM
rhubbard's Avatar
rhubbard
If you want the maximum noise/pop, do what I did. 2.5" all the way back. No cat. and no mufflers. Simply 2 resonators, one just about under the driver seat and one by the battery. On occassion I'll get a good crack.
Old Apr 16, 2007 | 11:08 PM
Scavenger's Avatar
Scavenger
Perhaps, but I don't have a stock ECU. I have the Dinan Stage 5, so maybe it also carries over whatever settings are needed for good "pop pop".
Old Apr 17, 2007 | 07:21 AM
flyboy2160's Avatar
flyboy2160
my supertrapp without any resonator pops and cracks like a wrc car.....love it!!
Old Apr 17, 2007 | 08:07 AM
mgibson61611's Avatar
mgibson61611
+1 for the Dinan exhaust
