Drivetrain Upgrade recommendations?
Old Apr 5, 2007 | 05:04 PM
Ion28's Avatar
Ion28
Hey everybody,
I'm going to be taking part in a high performance driving school in October at Buttonwillow Raceway, and I wanted to know what you guys think I should do to prepare my car (and myself) for it.
So far I've these performance/suspension upgrades on my 06 MCS:
JCW Brakes
m7 STB, USS, Intake, Aerogel EX (backordered)
Borla Street Exhaust
Shoe's Engine Damper
What else would you guys recommend?
Thanks all,
Matt
Old Apr 5, 2007 | 05:09 PM
Eric_Rowland's Avatar
Eric_Rowland
Fill the tank, tighten the nut behind the wheel, and you're good to go.
I've tracked a stock Cooper and stock S. Both fun.
But... if you like neutral handling, I'd add a rear sway - 19 or 22, depending on your preferences. My stock S plowed pretty seriously at Buttonwillow.
Old Apr 5, 2007 | 05:31 PM
Gr8Force's Avatar
Gr8Force
REAR SWAY BAR!!!
Pulley just for that little extra umph!
Old Apr 5, 2007 | 05:32 PM
MiniMacPR's Avatar
MiniMacPR
Yep, I was gonna say the rear sway too. You already have the JCW brakes, I don't know if they already have stainless steel brake lines on the kit, but if not they are a good idea also. Make sure you change your brake fluid before the day comes; ATE blue or Motul are the usual recommendations there.
Have fun!!!
Old Apr 5, 2007 | 05:50 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by Ion28
Hey everybody,
JCW Brakes
Get a good SA2005 or M2005 rated helmet that fits you well.
What tires and wheels are your using? Stock ones?
Before you go, put in brake fluid that withstands higher temps before boiling, the stock fluid isn't so good.
Add adjustable rear sway bar, could be 19mm or 22mm, softest setting would be good place to start.
Read-
http://www.amazon.com/Secrets-Solo-R...5820560&sr=8-2
Secrets of Solo Racing by Watts for $10.17!
Old Apr 5, 2007 | 06:38 PM
Ion28's Avatar
Ion28
Yeah, I'm using stock wheels (17" Webspokes) and the stock run-flat tires. I was planning on renting a helmet, buying some high temp brake fluid (like you have mentioned), and maybe better brake pads. Also, do you think it would be good to buy a Schroth harness, or wait to get into autocross for that?
Old Apr 5, 2007 | 08:19 PM
minimusprime's Avatar
minimusprime
camber plates and tires.
Old Apr 5, 2007 | 11:09 PM
Eric_Rowland
Do yourself a favor and buy a helmet. If you're going to be doing autox, you'll need one anyway. Put that $$ towards the one you want to buy. Rental helmets get pretty nasty.
A good first question is: What do you want to get out of the track day?
IMO, starting with stock rubber and brakes is a good idea, as you get a feel for how the car would feel on the street (vs. dedicated track rubber and brakes.) The Schroth is nice, as IT holds you tight as opposed to using the wheel to help keep you in the seat. But I wouldn't put it on the top of the list.
Again IMO, the track (especially the first couple) is about finding, expanding, and exploring your limits and the handling dynamics of the car, not being the fastest car out there. (you won't be!)
Old Apr 8, 2007 | 09:31 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
All of the above recomendations are great. I would seriously put in a pulley. I have a 19%, but since you are autox-ing do not excede 15% or 16%(m7). also think about a lightened crank pulley. and take the rear seats out if its allowed.
Old Apr 8, 2007 | 12:13 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
A rear sway bar will improve dramatically the handling.
If you have not change your tires yet, get rid of the runflat and buy a flat repair kit.
But if you want to have fun and improve your car, get a rear sway bar. It is a great mod and in my top five!
Old Apr 8, 2007 | 06:42 PM
minimarks's Avatar
minimarks
#1 Rear Sway Bar
molala
Oct 2, 2015 01:53 PM
Richard Worster
Sep 15, 2015 06:24 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
