Drivetrain The obligatory oil thread
Old May 12, 2003 | 04:36 PM
DK23's Avatar
DK23
Ok, I thought I would ask what brand and weight oil others are using in their MCS. I know the factory says 5-30, but with summer coming on, is everyone staying with that weight?
Old May 12, 2003 | 04:41 PM
itsthedirtybird's Avatar
itsthedirtybird
I just realized that I bought a case of 10w-30 instead of 5w-30 should it matter? Mobil one from costco.
Old May 12, 2003 | 05:10 PM
DK23's Avatar
DK23
I just changed to 10-30 Royal Purple. I have always used Mobil 1, but thought I would try RP. I am more comfortable with 10 for the low end in summer, but am also used t running 15-50 in a Porsche, so I am a bit freaked out at using 30 for the high end.
Old May 12, 2003 | 05:24 PM
Ryephile's Avatar
Ryephile
I'm running 5W-30 Amsoil 100% synthetic, no blend
Old May 12, 2003 | 06:29 PM
itsthedirtybird
so ten 10w-30 is ok? if so I will change my oil tonight!
Old May 12, 2003 | 07:10 PM
chrisneal's Avatar
chrisneal
If you do a search, I'm sure there are at least 20 obligatory oil threads...
Old May 12, 2003 | 09:54 PM
track-toy's Avatar
track-toy
To clear up a common misconception the W ( as in 10W30) means WINTER not weight. The lower the number on the left, the easier flow you will have in the winter.
Old May 13, 2003 | 06:17 AM
sjbartnik's Avatar
sjbartnik
In my service & warranty booklet, Mobil 1 is specifically recommended by name (as is the MINI-branded oil you get from the dealer). Grades 5W-30 or 5W-40 are also recommended.
10W-30 should be fine for the summer months though I don't think I'd use it for winter.
Old May 13, 2003 | 07:58 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
FWIW, I am using Mobil1 5W30 with an OEM MINI filter, changed every 5k miles.
Old May 13, 2003 | 08:24 AM
FraserBonnett's Avatar
FraserBonnett
Amsoil Series 2000 0W-30 Motor Oil
Old May 13, 2003 | 08:59 PM
minimc's Avatar
minimc
Chalk up another for the Amsoil 0-w30 full synth. Best synth going esp. for MINI
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
