Drivetrain P1125 Code - help?
P1125 Code - help?
I had two events last week that caused limp-home mode for a short bit until I could pul over to the curb and restart. Then no problems and ran smoothly.
I rented a OBD2 code reader from a auto parts store and it showed two code events each with P1125 code.
This code wasn't listed in the BMW code lists so I was wondering what it was and how to fix this as I'm planning on driving from the Santa Barbara area to Las Vegas for the AMVIV next week. I don't want to be stuck on the side of the road with this.
A search on this forum showed some "Throttle positioner" issues but not clear.
Thanks,
Paul
Thanks,
Paul
I don't have my list handy here but IIRC P1125 is related to the Throttle Body Position Sensor - basically the sensor that feeds back information to the ECU about where the TB butterfly is set. I had some issues with this and P1124 on my '02 MCS, it turned out to be the TB itself -- MINI replaced it with a new one after a week wait for one to be shipped in from Germany.
I see you have the M7 TB, so you've at least disconnected the cable before. I would make sure that the 4-pin cable to the TB is nice and tight (maybe reseat it).
No, no, P1125 is:
P1125
4389
Throttle Position Sensor A and B Range/Performance Small Error
P1126
4390
Throttle Position Sensor A and B Range/Performance Large Error
This is straight from the official MINI list.....
P1125
4389
P1126
4390
Where did you get an official MINI code chart? The BMW one does not list a P1125.
What was the fix for this....My friend had the same issue with a customers car and checked everything and found when he took off the throttle pedal and dropped it by accident everything went back to normal.
i just had this code yesterday when i was coming home and pulled over and cycled the key a few times and the EML light went away and the car was fine. I left work today and the eml light came back on so i limped back to work and scanned it and found the same code again...i took the pedal off and gave it a few good taps on the ground and put it back in and drove home fine.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
