Drivetrain FI induction and headwork? Why?
Old Mar 20, 2007 | 06:58 AM
  #26
justintime's Avatar
justintime
what would happen if you tuned with higher compression pistons with lower boost? what kind of effects would that have (not speaking of the MC just in general)
Old Mar 30, 2007 | 10:50 AM
  #27
justintime's Avatar
justintime
-bump- for my question...
Old Mar 30, 2007 | 11:06 AM
  #28
spillman's Avatar
spillman
Faster spool up... But I wouldn't suggest going over 9:1. The honda guys run that a lot.
Old Mar 30, 2007 | 11:42 AM
  #29
justintime's Avatar
justintime
how much pressure can the minis handle? faster spool up seems worth the trouble to me. that mixed with a little turbo could be pretty cool.
or a built motor with a big turbo and high compression. if you could cut lag on a big turbo seems like that could be a good set up if you have traction.. am I wrong?
Old Mar 30, 2007 | 02:09 PM
  #30
spillman's Avatar
spillman
Well traction is deffinately an issue on a MINI, any FWD for that matter. What type of power are you looking for? A 28rs will spool up pretty fast on the stock motor.
Not sure what the stock motor can handle. But mine has ARP head studs and CP pistons with stock compression. And I have been up to 32psi with no problems.
Old Mar 30, 2007 | 08:00 PM
  #31
justintime's Avatar
justintime
well I have a cooper, so if I turbo with highboost I will build my motor entirely. (kind of a futuristic thing that I will do) but im studying it now so I get it done completly right... I will be looking for anywhere from 350 to 415. basically something insane but without a huge kick. im not terribly into drag I prefure hitting up an autocross or track. so I want it to be drivable via out of turns exc without on off power. (but lots of power at the same time.)
Old Mar 30, 2007 | 08:06 PM
  #32
spillman's Avatar
spillman
Plan on building a stroker motor if you want something to spool fast enough for an autocross. I believe you would be more interested in doing a rotrex blower on a built motor.
In first and second traction is hard enough to come by at 300whp, not to mention trying to put it down exiting a corner. Unles you are running some wide *** tires in the front I would say 250whp would be all I would want at an autocross. But good luck to you. Glad to see more people are looking at modifications that actually make hp...
Old Mar 30, 2007 | 08:12 PM
  #33
justintime's Avatar
justintime
my thoughts exactly. thats kinda why I was thinking of a set up that would be much like a really powerful built motor. pulling strong at mid range rpm (enough to pull out of a corner without smoking the tires like your in rain/having to give it very little throttle) yet have ALOT of power on the straights. seems kinda hard to do.. but ive driven a gp alot and I know Im looking for more than the lower 200
Old Mar 30, 2007 | 08:15 PM
  #34
justintime's Avatar
justintime
thanks for your help btw :]
Old Mar 30, 2007 | 08:29 PM
  #35
spillman's Avatar
spillman
Hahahaha. I seriously doubt a GP makes even close to 200whp. See if you can't get a ride in a twincharged or turbo only car.
Old Mar 30, 2007 | 09:51 PM
  #36
justintime's Avatar
justintime
well, all my friends are tuners.. so ive driven a twinturbo 350z, turbo civic, a evo, sti, exc.. lots of highhorspoer cars just never a mini more powerful than the gp...
Old Mar 31, 2007 | 06:55 AM
  #37
herbie hind's Avatar
herbie hind
nothing substitutes cubic inches but if you're building a small car and want a sporty version, a quick way to give it some power is forced induction. the cheapest being s/c . does it stress the engine ? of course . would you want to stress it more for more power or invest in some head work that if done conservitively will add power without sacrificing longevity ?
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
Mini ni
Sep 24, 2015 05:42 AM
Sep 22, 2015 02:05 PM
