Drivetrain M7 thermostat
Old Feb 17, 2007 | 08:54 PM
mini22's Avatar
mini22
M7 thermostat
does the m7 thermostat look like the stock one or is it bigger
Old Feb 17, 2007 | 10:33 PM
billie_morini's Avatar
billie_morini
It looks a lot like the stock one. Outer dimensions are the same. If not, it could not be installed
Old Feb 18, 2007 | 07:53 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Here's a pic from the M7 site...
Old Feb 18, 2007 | 09:03 AM
Speedee's Avatar
Speedee
Heard several comments that the M7 'stat did not fit after all the work to get the stock one removed.... anyone else experience this problem???? This question is all that's holding me back from installing one.
Old Feb 18, 2007 | 09:09 AM
Partsman's Avatar
Partsman
Legion_of_Doom
You may want to call Peter and ask him. I remember something a while ago that some were not "cut" correctly.
Old Feb 18, 2007 | 10:37 AM
M7's Avatar
M7
Hi Guys....
The M7 Thermostat is a direct replacement, that will match up with the OE rubber gasket. We did have a batch mid last year that was improperly cut
and consequently did not fit perfectly. Everyone got the replacement unit promptly. If you live in a cold climate, please use the 180 degree thermostat during the summer months, as the ecu will throw a cel light as soon as temps go below 45degrees.
peter
M7 Tuning
562-608-8123
Old Feb 18, 2007 | 11:05 AM
meb's Avatar
meb
It is a direct replacement. I reinstalled my stock thermostat, however. with temps below zero in the am for about 5 weeks, the car was not running well and fuel mileage dropped off by about 3-4mpg.
Old Feb 18, 2007 | 11:14 AM
ca$per's Avatar
ca$per
I'm currently using the M7 thermostat and as peter said (it is a direct replacment) and till now there is no problems at all.
all the products I got from M7 (via CMS) fits nicely and easily to my Mini and have high quality finish... this is by no means an advertisement to M7 just my personal openion based on my experience with the products (I live like 100000 miles away from LA )
if the weather in your area is as hot as, or close to, the weather here then GO 4 IT.
vulkandino
Oct 31, 2015 08:29 PM
Cruzer214
Oct 11, 2015 07:45 AM
navybsn
Oct 4, 2015 03:27 PM
tag1260
Sep 29, 2015 03:53 PM
silence2-38554
Sep 28, 2015 12:19 PM
