Drivetrain Throttle Body testing
Old Apr 29, 2003 | 08:41 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
After much research the throttle body is finally closing in on the home stretch. We will be doing dyno testing tomorrow, but the unit functions at all RPM ranges, has no idle problems, and makes a noticeable difference without tripping any service engine soon lights.
Stay tuned for the dyno results.
Randy
Old Apr 29, 2003 | 08:45 PM
caddman's Avatar
caddman
Awesome!! Keep me posted for when its ready to ship....
Old Apr 30, 2003 | 05:33 AM
paulmon's Avatar
paulmon
I have talked some more with Leitner Performance and they seem quite confident that they can do the work on the MINI's throttle body. Now I have to find some time to rip the throttle body out and bring it to them to see for sure.
Will keep everyone posted.
Cheers,
Paul
Old Apr 30, 2003 | 07:01 AM
Antranik's Avatar
Antranik
How many hours of labor does it take to change the unit anyway?
Old Apr 30, 2003 | 09:01 AM
Yeagy's Avatar
Yeagy
From what ive heard it is pretty simple. Maybe 30mins-1hour at most. Just unbolt old- rebolt new.
Old Apr 30, 2003 | 12:38 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
There is a good "how to" on this site for changing the throttle body.
Looks pretty easy.
https://www.northamericanmotoring.co...pic=5680&0
Old May 1, 2003 | 12:41 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The throttle body takes a half hour at most to change.
I had the dyno reserved today, but never got away from the phone! I have it as my top priority tomorrow.
I'll be doing some more base runs for the ECU, then testing the throttle body.
We'll see!
I have track time scheduled this week again for more ECU and intercooler data gathering. I'll be sure to post the results of that as well.
Randy
Old Jun 7, 2003 | 03:34 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Randy says that the throttle body is starting to be made now and soon the first orders will be filled.
The guy who does the upgrades from the stock parts is now well enough to work and the first five units were just sent
out to be redone in California. Hopefully all goes fine and the units can be made in enough supply to meet demand.
Should add about 5HP.
Old Jun 7, 2003 | 07:59 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
How are the throttle body halves being reconnected after the modification work is done? Will it be duct tape, like the item shown in the Mini-Madness catalog?
Old Jun 7, 2003 | 04:21 PM
Chitown_COOP's Avatar
Chitown_COOP
Coordinator :: Chicago MINI Motoring Club
Nice.
Old Jun 7, 2003 | 07:49 PM
BlueMCS's Avatar
BlueMCS
Nice catch Andy......
...here we go again!!!???
Old Jun 8, 2003 | 03:39 PM
track-toy's Avatar
track-toy
I think I'm in the first batch to be delivered. I was on the phone to Randy when he got the go-ahead to release the product. So I ordered it right there!
Old Jun 8, 2003 | 03:54 PM
TonyB's Avatar
TonyB
Hey, if not much trouble, please share how the install goes and your driving impressions. Thanks!
Old Jun 8, 2003 | 04:15 PM
greatgro's Avatar
greatgro
>>Hey, if not much trouble, please share how the install goes and your driving impressions. Thanks! >>>
Ditto.
Ditto.
Ditto.
Old Jun 9, 2003 | 09:58 AM
Redleg13's Avatar
Redleg13
yup, please let us know how the install goes and your perceptions as to any performance improvement noted...
Old Jun 9, 2003 | 01:38 PM
MCSHP's Avatar
MCSHP
I saw this up close, its not duct tape. It some sort of metal tape but they tell me that this was just a prototype. Not sure what they will use in the end. Randy, whats your sollution?
Old Jun 9, 2003 | 03:10 PM
jlm's Avatar
jlm
So far, I have machined two throttle bodies to 61mm, and prepared three machining jigs for production. After the last discussionw with Randy, I am awaiting delivery of a starter lot of stock bodies. The set-up time makes the work do-able (read "affordable&quot only if I can do a minimum run of ten. I have been running one for a month in my car with no problems whatsoever...I'll let others report on the power gains.
The steel band has to be cut off; I add a screw clamp device as part of the tweak.
Old Jun 9, 2003 | 03:28 PM
TonyB's Avatar
TonyB
I heard that there were some driveability issues with the 63mm. I believe Madness advertises that TB on their site. Are they indeed for sale? I sort of thought that is why Randy is rolling with the 61...
If someone can enlighten, that would be much appreciated.
Thanks.
Old Jun 9, 2003 | 10:28 PM
bluethunder@promini's Avatar
bluethunder@promini
John,
Send me one, I'll test one out!
Al
Old Jun 10, 2003 | 07:40 AM
SUPRCHRGDMINI's Avatar
SUPRCHRGDMINI
JOHN,
you know me and jeff ae always up tp do little testing. let us know how much and when you will have them ready
Old Jun 10, 2003 | 08:29 PM
Daytona955i's Avatar
Daytona955i
Actually, real duct tape (as in heating ducts) typically does have a metal foil outside and does not look like typical duck tape. This is what they probably used.
Old Jun 11, 2003 | 06:28 AM
track-toy's Avatar
track-toy
>>Ditto.
>>Ditto.
>>Ditto.
Yeah, I can't wait to get the TB. Looks like I'll get it about the same time as our Texas pulley install (June 20-21). I'll sure let you know how the TG drives!
Tonyb, The 63mm had idle speed problems so Randy went with 61.5mm and the problem went away. Too much air I guess on the 63 for the ECU-programmed fuel flow.
Old Jun 11, 2003 | 06:30 AM
track-toy's Avatar
track-toy
Read that as TB!
Old Jun 11, 2003 | 12:17 PM
TonyB's Avatar
TonyB
Thanks for the follow-up mckinneymini! Please do share...
Maybe future ECU maps can accomodate a 63, and not pose such problems. Time, time, time. Thanks again.
Old Jun 11, 2003 | 12:23 PM
andy@ross-tech.com
I wonder if the idle problems with the 63mm were due to manufacturing/design defects which allowed unexpected air into the inlet tract while under vacuum. An incorrectly seated TB or missing gasket could cause the same idle problems.
