Drivetrain Gauges...finally
Old Dec 16, 2006 | 10:43 PM
  #26
sddave's Avatar
sddave
I really like it, nice job!
If I can ask, where did you tap into for the water temp?
Old Dec 16, 2006 | 11:00 PM
  #27
COR BLMY's Avatar
COR BLMY
Originally Posted by PARTSMAN
The factory sender hole. Use a 3/8" pipe thread nipple, 1" long(maybe 1 1/2" i'll check), get a female tee, grind off the "T" part, run a tap down it. Screw the nipple in the block, screw on the tee so the part you ground off is on the side, put the factory sender in the end and your gauge sender in the tee.
BE CAREFUL ...
I had this set up and the extended tube fractured on the turn to the front straight at Las Vegas Motor speedway. If you do this and run the stock sender and a sender for a guage there is a big chance of the T / extender failing !
I now run a SS line and a remote sender
Old Dec 17, 2006 | 08:45 AM
  #28
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks.
I tee'd off where the stock water temp sender is, and it wasn't easy. It required more modified brass fittings, just like the oil press setup.
Old Dec 17, 2006 | 08:55 AM
  #29
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by COR BLMY
BE CAREFUL ...
Thanks for the warning. I will check it periodically to make sure it's ok.
Old Dec 17, 2006 | 09:19 PM
  #30
MINI Monkey's Avatar
MINI Monkey
That is a really nice gauge setup!
Old Dec 18, 2006 | 05:58 AM
  #31
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks!
Old Dec 18, 2006 | 06:49 AM
  #32
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Originally Posted by not-so-rednwhitecooper
and its a 69
and am i safe to assume the car was an SE, non R/T?
You got the year correct, but not the car. Think smaller.
Old Dec 18, 2006 | 06:50 AM
  #33
Partsman's Avatar
Partsman
Legion_of_Doom
I was thinking a Dart.
Old Dec 31, 2006 | 05:53 PM
  #34
Partsman's Avatar
Partsman
Legion_of_Doom
Update on my water temp sender location, I originally had moved the stock temp sender away from the head, and tee'd off of that for the Autometer sender. Not good. I was getting a code for a "coolant thermostat malfunction" apparently the sender wasn't getting as hot as it should have been. So I put it back in the head and made a "T" to replace the stock plastic one that has the return line to the expansion tank. It should be ok now.
Old Dec 31, 2006 | 06:09 PM
  #35
Arly's Avatar
Arly
Here how I tapped that gray with red stripe. I used a quick tap from NAPA.
Old Dec 31, 2006 | 07:49 PM
  #36
Yeah, as Partsman says, probably Dart then. I know its a 69 becasue of the 69 steering wheel. The dash is rather simmilar, the only thing I can see in the pic that throws me off are the doors. The strutcure of the door doesnt look Charger, but the dash does.
Old Dec 31, 2006 | 09:05 PM
  #37
ScuderiaMini's Avatar
ScuderiaMini
me likey
Old Dec 31, 2006 | 09:08 PM
  #38
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by ScuderiaMini
me likey
Thanks man, Happy New Year.
Old Jan 1, 2007 | 06:50 AM
  #39
Soul Coughing's Avatar
Soul Coughing
looking good! happy new years to you too!
