Drivetrain Another belt question
Old Dec 5, 2006 | 03:56 AM
NMgokart's Avatar
NMgokart
Just picked up a Helix 19% pulley and have read all of the recommendations re: the Gatorback belt. Should I be concerned that since the Helix is a shoulderless design, the Gatorback might have a tendency to walk off the pulley? The grooved pulley/ belt system would seem safer in this regard, but then you all have experience with these things.
Old Dec 5, 2006 | 04:04 AM
stevecars60's Avatar
stevecars60
The Goodyear belt will work just fine.
Old Dec 8, 2006 | 07:25 AM
jymontoya's Avatar
jymontoya
I just put a Gatorback on mine with my 19% install last weekend. The slight whine really emphasizes the supercharged car!!
At first I loved the performance, about 16psi at redline in 2nd, but now I'm only making around 14 psi of boost at redline in the same gear... I'm thinking my bypass valve is failing?
Old Dec 8, 2006 | 07:44 AM
camminich's Avatar
camminich
The agressive "teeth like" pattern of the Gator back works well with both groved and smooth pulleys. Even without the shoulder, it still will stick tight.
Old Dec 8, 2006 | 02:08 PM
herbie hind's Avatar
herbie hind
your belt may have stretched a bit and is slipping a little . i'm seeing alot of type on the 19's slipping tendencies.
Old Dec 8, 2006 | 04:02 PM
NMgokart's Avatar
NMgokart
So would a shorter belt be appropriate? Or just keep changing them as they grow and start to slip?
Also, if you don't mind, what is the Goodyear# for the 19%?
BTW, thanks all, for the answers.
robbiedowns22
Aug 25, 2015 12:20 PM
PhoenixR61
Aug 19, 2015 10:27 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
