Drivetrain Stiffer engine mount options
Old Dec 2, 2006 | 07:09 PM
  #26
rkw's Avatar
rkw
Getting off-topic on bracing, but...
It would be very interesting to compare the GTT braces with the M7 USS. Doubtful however that someone would buy both of them, especially since the customer base of the two companies is quite different. I have the M7 and it is fantastic on my cabrio, and its effectiveness has been well documented by buyers. Roland hasn't seen or tried the M7 but expressed doubts about its design and build.
do you mean the bar that M7 do thats about 5 inches further back than ours? If so it IMHO will do next to nothing (single small bolt at each end so a pivoting action can occur up/down and front/rear ,not even clamping directly into the chassis and looks in the pics Ive seen of only small section material) .
Or the one that AFAIK is a frame clamped over the existing centre tunnel brace/exhaust hanger plate.?This one we may do but tbh the existing plate serves the purpose well and is not in a highly stressed area to realy warrant further bracing unless your after the last 1%. (Ok you are )
Best Regards Roland GTT
Old Dec 2, 2006 | 09:09 PM
  #27
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
I have on my car and sell the Ireland Engine Bushings. they are very nicely priced and they fit and function well. you will feel the engine a bit more, but very solid and a must for any tracked car. use one set or add them all. Trans Mount, Lower Engine Mount, Upper engine mount (not needed for 05-06 cars).
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 2, 2006 | 11:52 PM
  #28
spillman's Avatar
spillman
I had a cutom set of delron mounts made for my car. There is alot of vibration but the motor doesn't move.
Old Dec 3, 2006 | 02:56 AM
  #29
daleCarlsbad's Avatar
daleCarlsbad
Originally Posted by Patagonian GT
quicker acceleration from an engine damper? no butt dyno is that finely tuned
Clarification…………..the throttle response is quicker, so one could rightfully say that the acceleration is quicker as well.
Old Dec 3, 2006 | 08:27 AM
  #30
minimc's Avatar
minimc
Hey there Mr. Detroit Tuned
Seem to recall maximus having busted his OE torque link, and possibly Rye.
Whatever happened to that lower torque link & up'd durometer elastomer? Did you you get one? If so, what if any benefit did you see (relative to this conversation)? AND Are they still produced? I'm thinking if we're increasing durometer stiffness, and placeing struts on the upper mount that lower link may become "the weak one".
Thoughts?
Old Feb 19, 2007 | 06:55 PM
  #31
LordOfTheFlies's Avatar
LordOfTheFlies
I suggest you install one of my kits. You will be surprised.
The engine does not buck and so you no longer have to wait to shift....and thus you have faster acceleration by being able to shifter quicker than before.
Old Feb 19, 2007 | 07:13 PM
  #32
PGT's Avatar
PGT
thanks for the plug, but I've already got TSW kits in both cars
Old May 5, 2007 | 09:19 AM
  #33
OldRick's Avatar
OldRick
BTW, the OMP lower strut brace reduces NVH from urethane lower engine mounts somewhat.
My theory is that the opposing sides of the engine compartment work against each other when tied together with the bar, and suppress some resonances in the body structure.
silence2-38554
Nov 12, 2015 09:39 AM
Aug 12, 2015 01:24 PM
M7Speed
Aug 6, 2015 01:48 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
