Drivetrain m7 or alta
Old Nov 17, 2006 | 12:13 PM
  #26
Trickle X's Avatar
Trickle X
Originally Posted by ALTAPerformance
SpiderX: We certainly weren't trying to start any issue or "p****" match. But for something TRULY new and different check out our PWI1 system
http://www.altaminiperformance.com/p...jection-System
This works with ANY intercooler upgrade or stock.
Hope that helps!
Thanks again folks! We always appreciate the opportunity to help!
I wouldnt hesitiate to use a water/meth injection system as I used a Snow Performance kit on my Cummins Diesel. On the Diesel it was aiding near 100hp gain alone. But I wont get one till Alta fixes the header issues on the Twurbo kit. I have been waiting far to long, and everytime a new product comes out it does erk one a bit.....fwiw
Old Nov 17, 2006 | 12:45 PM
  #27
ALTAPerformance's Avatar
ALTAPerformance
TRickle X: Thanks for the comment and the information. If you are having an issue with a TWURBO™ please let us know! You may also want to check out the 3" exhaust for the TWURBO™ too!
We are always here to help!
Thanks again!
Old Nov 19, 2006 | 07:55 PM
  #28
GreenIguana's Avatar
GreenIguana
Alta guys - what about the M7 scoop, I have one - will it work with your intercooler V2???
Old Nov 20, 2006 | 08:54 AM
  #29
ALTAPerformance
Thanks for asking! We haven't tried it ourselves, but it certainly appears that it would work fine. Because the opening on the M7 core is narrower, it may require slight additional trimming to match the larger mouth on the ALTA V 2.0
NOTE: To the group. If someone does this can they post photos please? We have lots of clients with the same concern and would love to send them to get the scoop if it works.
Thanks to all!
Old Nov 20, 2006 | 11:42 AM
  #30
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Here's what most scoops look like:
Only one on the planet looks like this:
Thanks to all!
Old Nov 20, 2006 | 11:45 AM
  #31
MSFITOY's Avatar
MSFITOY
Phil...what are the last two?
Old Nov 20, 2006 | 11:51 AM
  #32
Partsman's Avatar
Partsman
Legion_of_Doom
Sid, The last two are actually the same scoop(i think). A DrPhil modified M7 RAM for the DFIC and his air box diverter.
Old Nov 20, 2006 | 02:13 PM
  #33
DrPhilGandini
Actually, the last 2 are 2 different scoops. The way that M7 gets the scoops laid up, it's like a sink--an outer shape and an inner shape, with an air space between and then glued together. When you cut them you quickly see the outer-gap-inner structure. Hence you can't simply "cut" the RHS of the DF scoop away and get my scoop. Much easier to modify the Ram scoop.
BTW, Sid--I installed the thermocouples this morning! No leaks. Now to install the gauge this evening...then off to measure.
cheers,
Debi's Coop S
Dec 27, 2015 02:35 PM
vulkandino
Oct 31, 2015 08:29 PM
Joeygonz
Oct 4, 2015 09:25 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
gnhovis
Sep 28, 2015 06:28 AM
